Question about Maytag MMV4205 Microwave Oven
Maytag Microwave OTR MMV4205BA just started having problem with it going through a power cycle when cooking. I.e., I put some food in there, press 30 seconds, it comes on for a few seconds, and then shuts down, screen goes blank, and then the screen powers up and goes into the "PLEASE TOUCH CLOCK AND SET TIME OF DAY". I tried unplugging the system for 10 seconds, and the problem still occurred. I tried heating at a lower power setting (e.g., type 30, then power, then 2, then start), and that didn't cycle the power this time. Don't know yet if this is a consistent solution. The problem doesn't always occur. This morning it worked fine. Last night it was problematic. It does still heat food appropriately. Nothing else in the kitchen on the same circuit power cycles when the microwave does it, so I'm assuming it is something in the microwave.
  • Anonymous Dec 07, 2010
    Yeah, I was assuming it was the control panel.
    Now it fails the same way on any setting, yet occasionally, the lights will dim for a bit, and then return to normal, and it will continue functioning normal for the remainder of the time on the cooking cycle.
    So I wonder if a discrete part (diode, capacitor, etc.) is failing, yet not totally failing. Or perhaps there is a loose solder joint? If this is likely the case, I'd rather rather tackle this before investing $200 in a new control panel.
    Suggestions?
    Thanks,
    Henry
Anonymous
  • 476 Answers
Hi, on the Maytag MW oven, it is possible that one of two things is hapenig:
One would be an erratic door latch switch, that might be cutting the power to the control panel(digital display)and that is why the panel kind of does the power reset, but I am more inclined to a control panel that is starting to loose one of its components, the fact itself that you can set a lower power level for cooking and the oven goes through the cycle normally is a sure indicator that the control panel is involved. Out of the two possibilities the switch is the most economic. Both the switch and the control panel are available from www.partsclinic.com, just type in your model number in the search window, and a full list of available parts and pictures are displayed. I hope this helped and good luck.
Posted on Dec 03, 2010
Our microwave, a Summit OTR 24 (built in cabinet with venting), will tend to shut itself down if we cook something longer than, say, 8 minutes straight. No power, lights on panel out. Then a few...
Sounds like the electronics overheated. You'd have to pull it and examine the insides to see what has gone bad. It could be pretty much anything.
Dec 20, 2014 | In Microwave Ovens
I have a Kitchenaid YKHMS147HW microwave that started turning on by itself, and will not shut off unless I unplug the unit. If I put food in to cook, the food starts cooking as soon as I plug the unit in,...
Sounds like stuck relay contacts. Magnetrons need a high voltage source which is controlled by a micro to relay and then from relay to voltage source. Even the turntable works via a relay.
Oct 14, 2013 | Microwave Ovens
Not heating
Hello
Power Supply
Check whether there is a proper power supply. Look to see whether the cord is connected to a grounded 3-prong outlet and the cord is fully plugged in. If the electrical system is built-in and no power cord is visible, replace or reset the household fuse or circuit breaker.
Microwave Functions
Some basic microwave operational steps may affect whether the microwave is heating. Open and close the microwave door, as the unit will not function with the door open, and push "Stop/Clear" to cancel any previous settings, such as the timer, which do not heat the microwave oven.
Setting the Microwave
Once the power to the microwave has been reset, or verified as working, and the microwave is ready to run, select a new cook cycle and press "Start" to see if the microwave begins to run and cook food as expected. Allow the food to cook for the alloted time and then open the microwave door and check to see if the food has cooked or heated. Choose a longer cooking time and restart the microwave if food is heating but is cooking slowly.
Repair
If all efforts to troubleshoot the function and power to the microwave still do not get the appliance heating food as expected, there may be a repair issue that needs to be addressed. Contact professional technician for advice.
Oct 05, 2011 | Sanyo Microwave Ovens
Burns my popcorn constantly. is there a different setting i can put it on?
HELLO.
Solution to your microwave problem is given as below.
* 1 Set your Daewoo microwave on a countertop near an electrical outlet and plug it in. Open the door and place the circular roller guide in the center of the oven cavity, then place the glass cooking tray over it.
* 2 Set your food on a microwave-safe dish and then put the dish on the cooking tray and close the door. Make sure that it latches properly.
* 3 Turn the upper knob to select a power level. Power levels include "Defrost," "Med-High," or "High." If your Daewoo has a touch pad, touch the "Microwave" button once to set the highest power level. Touch it consecutive times to lower the power level.
* 4 Turn the lower knob to set the cooking time. For cooking times less than two minutes, turn the knob up past the two-minute mark, then back to the correct time. For touch pad models, enter in the cooking time with the numerical keys and then press "Start."
* 5 Open the door at any time to stop the cooking and check the temperature of your food. Shut the door to automatically continue cooking, or turn the timer knob to the right to add more time. For touch pads, press the "Stop/Clear" button, then key in a new cooking time and press "Start."
* 6 Open the door when the timer reaches the "Off" position and take out your food.
Thanks.
Sep 24, 2011 | Daewoo KOC-925T Microwave Oven
May microwave Oven Model MMV4205BA won't heet
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Aug 10, 2011 | Maytag Microwave Ovens
I inherited a 1986 J.C. Penney Microwave and can't figure out how to program most of the features. I need an operating manual or a gnome.
The clock must be set before you can use the microwave. When you plug it in, it should read all zeros. Enter the time, and press "Clock Set." Time is in 12-hour format. There is no daylight saving time.
For basic microwave use:
1. Press "Power."
2. Press the keypad corresponding to the desired amount of power, e.g., "High," or "Defrost." (The numbers on the keypad have little words on them, like "Warm," "Med," and "High".)
3. Press "Time."
4. Enter the desired cooking time, e.g., "1-0-0" will be 1 minute; you could also do "6-0" for 60 seconds. You can do as little as 1 second, up to 99 hours 59 minutes. "1-0-0-0" would be 10 minutes. "2-0-1-2" would be 20 minutes 12 seconds.
5. Press "Start."
NEVER operate the microwave when it is empty. Put at least a glass of water in it. Never put a glass in it empty; make sure the glass has something in it, like water. Be careful when taking out a glass of water that's been heated; the water has been known, in rare instances, to "explode" and severely scald people.
It is okay to use the approved metal rack (it's coated with ceramic to prevent arcing) when using the microwave in microwave mode. Of course, the metal rack is also fine for use in the convection/combination mode.
"Defrost" cycles between microwave and nothing, microwave and nothing, microwave and nothing. You can hear the cycles. If defrost takes too long, try "Low." Try to avoid using "High," as it kills most nutrients in the food. Opt for "Medium" for slightly longer time; it'll be more evenly heated and healthier. Some things, like popcorn, require "high" power.
To stop the microwave in the middle of cooking, simply open the door. (There's no such thing as microwaves escaping the oven and bouncing around the kitchen and zapping you. I have a microwave tester, and the moment you open the door, all microwaves dissipate; the reading at the door is "Zero" once it's opened.) Or, press "Cancel." If you open the door, you may test the food, and if it needs further cooking, you may close the door and press "Start," and it will resume where it left off. If you're all done, just press "Cancel."
There is no way to disable the 5 beeps at the end of the cycle. If the baby is sleeping and you don't want to hear the beeps, simply open the door right before the beeps when the countdown is at zero. Pressing "Cancel" will give you one beep.
If you have the Combination feature, that cycles between microwave and convection heat, giving the best of both worlds (cooking inside with microwaves and outside with convection), for things such as a whole meats.
To use Combination:
1. Press "Combination."
2. Consult the chart on the microwave (below the keypad) and choose a number from 1 to 4, depending on what type of food you're preparing (i.e., lamb, pork, etc.).
3. Press "Time."
4. Enter the desired time, using the method described above.
5. Press "Start."
The Convection feature simply blows hot air across the food, at the temperature and duration that you set. It's a great way to toast slices of bread for the whole family at once, or bake a pizza.
To use the Convection feature:
1. Press "Convection."
2. Choose the temperature (the degrees are printed on the keypad, such as "350 degrees."
3. Press "Time."
4. Enter the length of cook time, using the method described above.
5. Press "Start."
Be sure to cover foods (with a paper towel or suitable plastic cover) that are prone to splattering. Don't let foods explode and get up into the motor. Clean the inside regularly with a soft sponge and mild detergent, NOT harsh or abrasive chemicals like Comet. Then rinse the soap off with a clean sponge.
Be sure to close the door firmly before cooking, but don't slam it. Slamming it will wear out the latching part, but being too gentle in closing the door may cause the safety switch to not engage, and the microwave won't work (it'll count down and the light will turn on but the motor won't run).
Note: the Convection feature uses more wattage than the microwave counterpart. The volts and amps are listed in the door jamb; multiply them together and you get total watts (although the actual amount will vary depending on your "power" settings).
Aug 07, 2010 | Microwave Ovens
My food no longer rotates while cooking,and it makes a clicking noise.
this is usually a bad turn table motor. if you remove the screws out of the bottom of the otr(over the range) it will hinge down and back and you will see the motor in the middle of the otr. your local parts house should have this item in stock or be able to order it for you
Apr 24, 2010 | GE Advantium 120 Convection/Microwave Oven
How doI change the power on my microwave?
  • Press "Time Cook" or "Micro Cook."
  • Enter cooking time.
  • Press "Power Level".
  • Select a desired power level 1-10 (default is 10).
  • Press "Start"
Jul 06, 2009 | GE JES1855 Microwave Oven
Maytag MMV4205BA microwave buzz/grind when operating then no power
you may have some arching inside where your magnatron is located.If you open the door on the right middle part there is a silverplate on the wall .If it is burned you may need to replace magnatron.if you do not seee burn marks it may still be the magnatron hope.that would be the only possible thing that would make the noise other then the mtor plate out of place.
May 15, 2009 | Maytag MMV4205 Microwave Oven
Maytag MMV4205 Microwave Oven Logo
104 people viewed this question
Top Maytag Microwave Ovens Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Paul Bade
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
