Question about Soyo DYLT032D 32 in. LCD Television
Hello When I light my soyo tv model #: MT-SYTPT4227ABMS The screen turns (a small flash and turn off) the red light indicating that the tv is connected s' shuts down (does not light green) When that happens, I must: 1-unplug the TV 2-wait 10 seconds 3-I reconnected the hurry to press the power button 4-repeat step 3 until it works Until very lately, it worked well .... but now nothing works ... what to do thank you answer me at this address [email protected]
Posted by sebastien_mo on
5 Related Answers
Anonymous
  • 4 Answers
SOURCE: My Soyo DYLT032 has power but no picture or sound
Long story short:
Had the same problem with my Soyo.
Thought it was the power supply board problem that everyone else was reporting.
ordered one.  Plugged it in.  Did not work.
Inspected the Main/Logic board and found what looked like a black button that could be depressed.  It is located to the right of main processor on the board.  You can't really miss it.
With the TV plugged in, I pressed the suspect button.  The TV made a buzzing/clicking noise for a few moments and the stuck blue illuminated power button faded away.
Curious by this, I pressed the power button and low and behold the TV comes to life!
Looks like I found a "reset" button which seems to have fixed my problem.
Thanks Soyo for not bothering to mention that such a button exists.
I hope the rest of you have the same good luck.  In the event you are still in need of a power supply board, email me.  I have a spare now it seems.  ;)
Posted on Jan 20, 2009
Anonymous
  • 6 Answers
I HAVE FOUND 2 2200uf CAPS ON THE POWER SUPPLY BOARD THAT ARE PUFFED UP. CHANGING THEM USUALLY SOLVES THE PROBLEM. THERE'S ALSO A RESET BUTTON ON THE MAIN BOARD YOU MAY NEED TO RESET AFTER CHANGING THE CAPS.
Posted on Jun 30, 2009
Chi Chu
  • 8457 Answers
SOURCE: my soyo lcd tv is not turning on properly..It
Ur main video backlight board is dying or dead much be replaced.
Posted on Oct 22, 2009
Anonymous
SOURCE: soyo model mtprtp3208nb
Replace all bad capacitors(end raised up) on power suply's main board. That'll fix it. fixed mine :)
Posted on Dec 21, 2009
Anonymous
SOURCE: TV will not turn on until I unplug, then plug it back in.
I have the same problem with my Soyo 32" lcd tv. Seems a lot of people do. Soyo went out of business, but I am going to see if it is the capacitors, like several people said on here.
Posted on Jan 28, 2010
Soyo Flat Screen TV won't turn on. Red light blinks but nothing powers on.
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy.
If you're sound in electronics, and wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Flip card, can be selected by the drop-down list, by the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window. google.com/+GopakumarGopalan
Nov 01, 2013 | Soyo Televison & Video
Remote code for the Soyo Model # MT-SYTPT4218AB What's your problem?
These are setup codes for Sanyo: 0049 0097 0110 0004 0268 0012 0108 0180
Oct 25, 2012 | Soyo SYTPT4218AB LCD TV
Soyo tv Mode MT-SYTPT3227AB will not turn on
It might be the power supply board. There is a repair service which addresses any problem with the power supply board, not just bad capacitors: http://www.coppelltvrepair.com/p/783/soyo-mt-sytpt3227ab-power-supply-board-repair-service-no-power-shutdown-etc
Jul 11, 2012 | Soyo SYTPT3227AB 32 in. LCD TV
Hello, I have recenty acquired a Philips CRT 29PT9420 Television. However. when i attempt to turn the TV on, the light at the bottom of the TV (Standby, On, Off light) flashes between green and red for 2...
Switch the TV on: Press the power switch A on the front of the TV. A green indicator on the front of the TV lights up when the screen is on. If the indicator is red, press the
-CH + keys on the remote control.
The green light blinks every time you press a key n the remote control.
Ref. link:
https://www.manualslib.com/manual/173137/Philips-29pt9420-69r.html?page=4#manual
Oct 11, 2017 | Televison & Video
SONY GRAND WEGA KF-50WE610 can't turn on TV screen.
Ths 5 blinks usually indicate an AKB problem. There is a break in the video path. I'll look up your specific model and post the results here. Please update this if you wish to attempt the repair yourself.
Thanks,
Dan
Mar 19, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Bell express vu remote codes for soyo tv
1 - Hold the clear tv buttom until all 4 light flash red
2- Press the red tv buttom
3- Press the amount of time needed on the up cursor ( around select buttom) until your tv shut down
4-When the tv goes off press the search buttom ( at the end on the right side )
5-Press record
Then u can use the red tv buttom to control ur tv and u can control the volume on satelitte mode without going back to tv mode , if u press too much time while searching the code and the tv wont light back , do the same thing but instead pressing the up cursor press the down one to go back on the code it will be faster .
Jan 02, 2009 | Soyo Crystal DYLT032B 32 in. LCD...
Soyo DYLT032D 32 in. LCD Television Logo
87 people viewed this question
Top Soyo Televison & Video Experts
Marvin
Marvin
Vish Iyer
Vish Iyer
Are you a Soyo Televison and Video Expert? Answer questions, earn points and help others
