Question about Excalibur. K9-MUNDIAL-SS Entry Level Auto Alarm with Dual Zone Shock Sensor
I have a blue flashing light that flashes when I set alarm and car is off . Is this normal and will it drain my battery ? ( 2002 Nissan Pathfinder )
Posted by lisa_m_dessu on
kenw392
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Dual Electro... Master
  • 2,226 Answers
The flashing blue light is to let potential thieves know that there is an alarm in the car. it uses minimal power and should not drain your battery.
Posted on Dec 03, 2010
Michele Perez
    New Friend:
Mine would drain my (new) battery and I know it was that light because after I disconnected it no more battery drain... I dont use my truck often so even though it was only a small amount of drain to the battery it was enough to need a jump after only a week of it sitting
Posted on Apr 30, 2013
95 nissan Pathfinder, blinking red center console light what is it?
as another member said, it may be an aftermarket alarm system??? take a pic and post it
Mar 04, 2015 | 1995 Nissan Pathfinder
Flashing theft light
Are you setting your car alarm? a flashing light that says theft on it is normally an alarm system that is activated when you lock your doors, if this is comming on during driving it can be due to the alarm system being disabled or other wise having problems.
Jan 29, 2013 | 2002 Ford Ranger Regular Cab
97 Nissan Pathfinder dash lights aren't working AND the alarm to turn off the headlights isn't working either.
i know this sounds crazy, but do you have break/tail lights?some cars shut off dash lites when tail/brake lights dont work
Jan 11, 2013 | 1997 Nissan Pathfinder
2000 maxima anti theft system draining battery
fault on a live connection,but check all your earths aswell
Nov 01, 2012 | Nissan Cars & Trucks
2005 Chevrolet Avalanche -
I would ask Firestone what they did.
Jun 08, 2017 | 2002 Chevrolet Avalanche
I have a 1889 dodge dynasty it starts and runs a few secands and turns off it restarts and the same thang happins it started this after the battery went bad could this be a securty prob
The alarm system, which is activated by hitting the auto-lock button, causes the battery to drain if set off. A pretty good deterrent for theft, but definitely not a owner-friendly feature.
You'll know that the alarm was triggered if, upon (your sad attempts at) starting the 1989 Dodge Dynasty, the "Alarm" signal to the left of the steering column flashes. It normally would flash a certain number of times, to denote "Alarm Set Off! I have drained the battery power in the name of Security!" But usually you battery will die first.
The only way TO FIX THIS PROBLEM: exit the vehicle. Place the key in the driver's side door. Turn the key once to the left (counterclockwise) to lock it. Then turn it to the right to unlock it and open the door. Enter the vehicle. Start the car.
You may have to try this a few times in order to be successful. If your battery has been toasted by these attempts (sometimes the horn will honk and headlamps light up and flash for added battery-drain quickness!) you may need a jump.
To PREVENT THIS STUPID STARTER/ALARM PROBLEM: Simply use your hand to lock the door. Do not push the electronic auto-lock button.
Jun 07, 2010 | 1989 Dodge Dynasty
I have a 2007 Pathfinder, normally when you activate the alarm the car honk goes off once. But now suddenly it does not do it any more. The lights keep flashing normally and the doors lock. Only problem is...
If you're finding it difficult to service/repair your car, get one of those online manuals. You'll not have to wait for others to answer, or rely on mechanics and all. Plus I know a website that has
very good manuals online, without expiry i.e. for lifetime.
www.reliable-store.com
Mar 05, 2018 | 2007 Nissan Pathfinder Off Road
Took the battery out to replace the fron left headlight. Once we put the batter back the car would not start and all lights inside and out started flashing. Started the car downhill in 1st gear and drove...
does this car have an aftermarket alarm system? it sounds like it does, as i dont ever recall seeing a blue flashing light in one of these cars. do you have an alarm / auto start remote control? try locking / unlocking the car several times with the remote, if it has a remote start try starting it with the remote a few times. try locking / unlocking the car with the key. good luck!
Jan 25, 2010 | 2005 Nissan Sentra
My 2001 nissan pathfinder is not starting am getting everything exept for spark.the security light is not flashing either and the problem starts after the security lite stopped flash.wat can i do?my email...
SOUNDS LIKE YOUR ALARM SYSTEM HAS DISABLED YOUR START CIRCUT. CHECK WITH DEALER FOR OPERATION OF YOUR ALARM CIRCUIT. AS FAR AS I KNOW THEY ARE THE ONLY ONES THAT CAN RESET IT.
May 05, 2009 | 2002 Nissan Pathfinder
How do I disconnect 1993 Nissan Pathfinder theft alarm
You should be able to unplug the control unit under the drivers seat to disable the alarm.
May 02, 2009 | 1993 Nissan Pathfinder
Excalibur. K9-MUNDIAL-SS Entry Level Auto Alarm with Dual Zone Shock Sensor Logo
799 people viewed this question
Top Dual Electronics Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Lawrence Oravetz
Are you a Dual Electronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
