Question about Rangemaster 110 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range
The plate warmer will not work tonight. Everything else seems OK. I've tried turning the appliance off at the mains and then back on again, but it didn't work
Posted by liz971 on
Anonymous
    New Friend:
Hi
I have just had the same problem, the connections just fall off the heater! Waiting for a response from Rangemaster....
cloudbase50
Posted on Jan 11, 2011
Have a electric cooker model nut grb6cvk no heat from main oven everything else working
Oven heater element has died. Get the serial numbers etc off the plate on the back or the handbook, go online to appliance spares sites and see if they carry an element. If you don't know how, get a good DIYer or appliance tech to change it. You could get them to check the element for continuity first?
Nov 15, 2014 | Leisure GRB6CVK Electric Cooker with...
Kelvinator fridge not cooling
Try defrosting the fridge. Check the cold plate at the back of the food compartment once the fridge has been defrosted and turned back on again. The cold plate in the freezer (around the walls) will be cold to touch as will the cold plate at the back of the fridge,
Oct 20, 2013 | Refrigerators
My ASUS K50IJ sound comes from only one speaker. I've tryed everything and the balance seems ok
One of the speakers failed or it has a bad connection.Most likely the non working speaker will need to be replaced.
Mar 29, 2013 | ASUS K50IJ-C1 Notebook
Whirlpool awo d 4305 s draining problem clothes left soaking
Ok, replaced waste pump - slight improvement but clothes still bad... only just seen your solution Mike!!! I didn't even notice a spin control board there, I will check/swap it tomorrow as I've only just put everything back in place(incl. kitchen cupboards etc!).
Is this a common problem with this model?? There's a mountain of appliances near where I work and I'm free to take whatever I can find, I'd say some people just buy a new machine without even checking if the filter's blocked looking at some of these appliances!
Thanks all!
Aug 22, 2012 | Washing Machines
Pioneer Rear Projection TV problems
a 240 ac voltage appliance will run happily on 220 volts but ther is obviously a fault as the green spark was possibly a fuse blowing
ie main fuse as power is not reaching the tv
Aug 14, 2012 | Pioneer SD-533HD5 53" Rear Projection HDTV
I've got a Alpha 240 e combi boiler..... Everything seems to be wor,kin ok but it won't start the ignition sequence .
could be air presure switch which tells pcb that fan is working and would then bring inn ignition system then main gas valve.Would suggest getting gas engineer in.pommie engineer
May 26, 2012 | Water Heaters
My Whirlpool Duet Sport Front-Loading washer stopped working. This morning it gave an F-25 error. We've unplugged it, plugged it back in, and I tried draining it but the drum seems like it's caught on...
http://www.assuredparts.com/WhirlpoolDuetWasherFaultCodes.htm
These are the fault codes for whirpool. The noise problem is what is bothering me.You can pull the bottom front panel, three screws and see if you have a problem with the wiring harness to the motor, also remove the clean out filter on the water pump and clean that out,(large 3 to 4inch diameter white plastic screw almost dead center and to the left of the pump motor). I would also pull remove the backing plate and check where the drum pulley attaches to the shaft, see if it is broken or makes noise as you turn it. You may see water or brown streaks coming from the bottom of the main bearing shaft assembly, This is a major repair. l would recommend you have a technician check this out, you may have a bad main bearing assembly, bad motor, or bad pump (unlikely) but you need a technician for most of these. I have also seen a sock between the inner and outer drum, causing the drum not to spin up to speed. Good Luck, Appliance Specialists
Dec 14, 2009 | Refrigerators
THE TEMPERATURE READOUT FOR THE FRIDGE AND FREEZER IS BLANK AFTER AN ELECTRICAL STORM. THE REST OF THE APPLIANCE SEEMS TO BE WORKING OK. GE PROFILE MODEL#PDS22SFSALSS
A power surge? Possibly main control board, guess it's on the back of the fridge /covered flat metal plate/.
http://www.subzerolosangeles.com
__________________________________
Sub-Zero refrigeration Service experts
Aug 15, 2008 | Refrigerators
Inspiron B130
Well start a bit slower then.
go into the bios at startup F2, and navigate around does it freeze there. if no then
start windows in safe mode F8 when windows logo shows.
freezing ?
If its not freezing then turn off the startup programs.
Start/run/msconfig and then uncheck load startup items
and start normally, click the dont show me this again /ok
any freezing.
If its freezing you may have a hardware issue.
if you have 2 sticks of memory remove on and or /reseat them
boot the dell diagnostics cd and check the cpu and memory.
report back
Jan 30, 2008 | Dell Inspiron B130 Notebook
Rangemaster 110 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range Logo
149 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Paul Carew
jdthefixer
john h
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
