My reciever wont power on but the standby light will come on and when i press power, the stand by light just turns off
Posted by jakim730 on
Electric Dime
    Master:
  • 434 Answers
It sounds like the output transistors may be putting this into protection mode causing the unit to shut down to avoid further faults. It will need to be serviced.
Posted on Dec 02, 2010
I have a Kenwood krx-89 standby light on please help
Krx-89 stand by light wont turn off - Fixya
www.fixya.com/support/t14712608-krx_89_stand_light_wont_turn_off
Oct 20, 2012 - krx-89 stand by light wont turn off Stero doenst play is it because thestand by light is on? How do i turn off - Kenwood Audio & Video Receivers ...
How do you turn off standby on a kenwood krx-89 stereo ...
www.fixya.com/.../t15447523-turn_off_standby_kenwood_krx_89_ster...
Dec 20, 2012 - Hi, is the red light that says power On? If not, it could just be the fuse since I had the same problem. If you take the lid off, it should be in the left ...
Read - Document Download
Dec 14, 2015 | Kenwood Audio Players & Recorders
Why does my tecknika 40-920 lcd tv no longer turn on? The standby light is on but when i press the power on button/change channel button the stand by light changes to on, but the returns to standby mo
Fault with main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 13, 2014 | Televison & Video
Why wont my Sony trinitron tv turn on but stand by light flashes?
That Flashing Standby Light Indicates A Defect In Your Low Voltage Or High Voltage Power Supplies...
May 25, 2014 | Sony FD Trinitron WEGA KV-36HS510 36" TV
PDP-4340HD keeps turning off.
Continuous blinks of standby light indicates a fault in the IIC data bus. The main board is likely to be faulty. If you wish to know more Check this link.
Feb 03, 2013 | Pioneer PureVision PDP-4340HD 43 in....
32'' emerson tv says digital telivision then nothing
press power screen reads digital television then the power light and stand by light turn on then screen goes black
Nov 26, 2012 | Emerson Lc320em1f TV
Wont power on
some tv's always have standby light on, even iff you turn off by tv button. solution 1: with light on, press a number on remote. solution 2: with light on press stand-by button on remote. solution 3: with light on push the 'on' button on the tv set. solution 4: unplug tv set, wait a few seconds then plug back in, if no light then turn on tv using button on the set, and then channel number.
Jun 25, 2012 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
Is it odd that my TX-SR606 Onkyo Receiver wont go into stand-by? It turns off but the standby light never lights.
try reset. push and hold vcr1 and then press power button while unit is on this will reset back to factory default
Apr 24, 2010 | Onkyo TX-SR606 Receiver
Reciever wont stay powered on
I fear that there's no easy fix. Sounds like the power supply or the board which controls it is bad. If you're not an electronics repair person, it'll need to go to a repair shop.
May 02, 2009 | Audio Players & Recorders
Ilo 32 lcd
I have the same issue. Here's a temporary solution, which is what I've been doing for the last couple of weeks, unplug the unit from the wall, just long enough for the red standby light to go out, then plug the unit back up. as soon that the red standby light comes on, press the on button the the remote or the unit. You may have to do this couple of time before it works. Somedays it works on the first try for me and then somedays I have to do it 3 to 4 time. I sure that at some point this will stop working too.
Sep 08, 2008 | iLO 3200 32 in. LCD Television
96 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
