Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
Hi I have a Coleman Eucon with electric ignition and it will on and run for aprox. 30 min. then shuts off. When I turn the switch off and then on again it will run for another 30 min. and have to repeat this process. is there anything I could do to fix this problem? If anyone could help me it would be much appreciated. Thank You.
Posted by jtrain99 on
5 Related Answers
mrgrzz
Dale Koehn
  • 88 Answers
SOURCE: furnace blower not working how it should
first off buy yourself a honeywell stat, in my personal opinion lux stats are garbage, I have run into so many that are bad stats !!! but as far as your fan not shuting down, sounds to me like your fan center on your circuit board is bad and will not shut down the fan when needed, you will have to replace the circuit board, as the fan center is a part of the whole of the circuit board, hope that helps
Posted on Jan 20, 2009
Scott Magill
  • 70 Answers
SOURCE: i have a coleman/evcon electric
Have you tried to replace pressure switch for the combustion air. If your not sure where to find it if you pull the front panels off follow the flue pipe down to combustion chamber the combustion fan motor is either inside the flue pipe or out side of it not sure on the one you have but you should see two plastic tubes that connect to a barb onto the topside of the fan and one on the bottom they both should go back to the pressure switch. i hope this helps you if you have any more question or if this doesnt fix the problem just reply back to this message . Make sure fan is working when furnace starts up. It should be the first thing that comes on when there is a call for heat
Posted on Jan 21, 2009
1STHVACMAN
  • 69 Answers
SOURCE: Hi I have a Coleman furnace that has the
If you mean hot surface ignition and not spark then look in front of the far burner from the glow plug and clean the rod in front of the burner with a piece of steel wool, the rod is probably dirty and can not sense the flame, so the gas shuts off.
Posted on Oct 11, 2009
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: Coleman furnace -- fan runs, ingniter won't light,
The chances are that the furnace was running when the power went out. This will cause the high limit switch to cutout and needs to be manually reset.
You will find that switch in the blower compartment near the blower. Usually somewher near the highest point of the cabinet.
Push the little red button firmly till it clicks.
When the power goes out while the furnace is running the heat builds up because the blower shuts down immediately and causes this limit switch to cut out.
If you have a electric tester you can also follow the low voltage circuit till you find the open switch. Ther is usually a wiring schematic on the door cover of most furnaces.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Posted on Dec 09, 2009
TheMobilian
Dan Webster
  • 8220 Answers
SOURCE: I have a coleman evcon
If the thermostat is ok which it probably is then your sequencer is most likely stuck i would say. You could verify that by removing 24 volts to the sequencer to see if it will shut down the heater
themobilian_598.jpg When low voltage from the thermostat is applied at the base of this sequencer it heats a bi-metal and turns on each coil and fan in a sequence that will insure the breaker don't throw from the power surge AND warm air comes out the vents when that fan comes on. I would start there.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Dec 28, 2010
We have a Coleman Electric Furnace Serial # AOL6042086, Model # AHP36C3XH21A and the fan runs constantly, will not shut off. We have replaced the thermostat and just replaced the control board. We h
I wish I was a furnace expert but I will give a push in the right direction. When a gas/electric fan runs it has two speeds. When you turn on the FAN ON switch it should run at the slower speed. If it doesn't turn on or turn off again when you turn it back you have a wiring problem or a thermostat problem. Make sure the thermostat is compatible with your unit and wired properly (on both ends). The other time the fan runs is "in session" when heat or cooling is applied to the system. It should run until the system finishes the cycle then a bit more (30 seconds or 1 minute) to blow the treated air completely through the ducts. If it doesn't stop then you may have a bad fan time delay or relay. Check parts for your model and various appliance repair site online.
Nov 25, 2014 | Coleman Mobile Modular Home Electric...
The oven turns its self ON every 20 to 45 mins. The electric ignition glows and the gas comes on and burns for about 30 to 60 secs then turns off. The oven control knob is turned OFF. There are no aut
Seems to me you have a defective control panel board.. Ovens should never do this. Time for the Serviceman right away, this could be dangerous if you are not home.
Nov 24, 2014 | GE Kitchen Ranges
;turn coleman hottub on - flashes "pr" for a few min. then it shuts off
If your Coleman has Balboa electronics 'PR' is to notify you that it is in priming mode.
It could also be your pressure switch. On most tubs the pressure is mounted on the heater. If this switch is not reading correctly it could shut the spa down to prevent heater overheating.
Sep 18, 2012 | Pool & Spa
Coleman Evcon BGU12520A won't ignite
check the ignitors condition is it cracked broken burnt out etc , ifn so then it will need replacing , or check the pressure switch is working try jumping it out and see if the ignition glows ,
Apr 09, 2010 | Heating & Cooling
My Frigidaire electric dryer GLER341AS2. The
Does it shut down completely? If it does, and the timer ceases turning, your problem may be a blocked vent pipe or Lint buildup.Your high limit switch is designed to kill power to your heater coils and sometimes the motor in case of overheat.
Mar 09, 2010 | Frigidaire GLER341A Electric Dryer
Can't start my coleman 1850 generator
Need more info,
Does it turn over??
Does it have spark??
Does it have fresh petrol??
Feb 25, 2010 | Coleman Sport 1850 Generator
Heatman101
Dec 09, 2009 | Coleman Propane Forced Air Heater...
On right turn car looses power let off gas its ok. No problem left turn?
Turn Signal Switch/ignition switch... Do it yourself in 30 mins with 10$ worth of tools u need to purchase...IF you want the process reply....THESE PARTS GM KNOWS ARE BAD!!!!
ANSWERED BY GARY KNOWS ALL
Be sure to know soon it will shut off the car and do worse....STALL?SHUT OFF?ELECTRICAL FLASHING? it will do it all
Oct 02, 2008 | 1998 Buick Park Avenue
Heating & Cooling Logo
52 people viewed this question
Top Coleman Heating & Cooling Experts
Paul Carew
Marvin
Marvin
jdthefixer
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
