Question about Kenmore Elite 44173 30 in. Electric Cooktop
Keys on the oven are not working so I can not start oven bake
Posted by khandan vahabzadeh on
Anonymous
  • 148 Answers
Thanks for posting to Fixya I will be helping you today. You have posted that you have a Kenmore Elite 44173 electric cooktop with a problem. However, you also mention your are having trouble with the oven not working. This post maybe categorized wrong but I will try to answer you question for both a range and oven control.
Sometimes on a cooktop customers will lockout the controls on accident while cleaning. Usually there is a button on the control that you hold for 4 seconds +/- and there is a little simbol of a padlock next to it or you might have to check the owners manual.
Lastly, Ranges may also have a lock out feature that the customer must press 4 seconds too unlock. On select models controls may also be locked out by putting their oven into sabbath mode. Usually the display will indicate a "SAB" to alert that this feature has been set.
*In general the above instructions should help if your unit is locked out.
Happy Holidays!
"Please rate this information "4 thumbs" if you found informational.
Posted on Dec 23, 2010
My frigidaire fef368gch was working fine and then the oven just stopped baking. It will broil but not bake. What causes this and how do I fix it?
Good Morning Shari,
I see that you are having trouble with your Frigidaire range, model# FEF368GCH, and the bake element not working while the broil element is. I suggest giving your appliance a hard reset, by shutting the power off at your home's circuit breaker, for 2-3 minutes. When power is restored, you will have to reset the clock by entering in the time and pressing start. Start a bake cycle, and if you notice that the bake element is still not working, I suggest contacting your local authorized technician. Hope this is helpful.
-Best Regards-
WP
Apr 23, 2014 | Frigidaire FEF368GC
OVEN DOES NOT WORK
Have you had a spill in the oven that could have blocked the bottom burner and baked on hard?
Mar 16, 2014 | GE JGSP28SENSS
Fisher & Paykel Thyme main oven not working
You could try reseting the clock to the manual position.
If in Automatic the oven won't turn on until set time.
Mar 18, 2013 | GE JB870 30" Free-Standing Electric Double...
Trying to set time, got stuck on wrong time, can't bake my turkey F90 displays when I press bake and a loud steady beep comes on until I press Stop. so I need 2 questions answered thanks
According to your service manual page 9 an F-90 is maximum oven door unlock time exceeded.
Here is your SERVICE MANUAL
This video shows how to check the door locking mechanism:
This shows how the electric oven high voltage portion of your oven works:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 01, 2011 | Kenmore Cooktops
Top burners work,broiler works,oven does not
check and make sure the bake element has continuity.If there is not continuity with your ohm meter then replace the bake element.
If it tests good the replace the main Electronic control board or the oven switch which ever the unit is equipped with
Feb 23, 2010 | Cooktops
I have a frigidaire gallery series, electrolux oven, we used self cleaning mode, worked great. Problem is the oven doesn't work know, broiler works, just the oven wont turn on.
often the bake ignitor will burn out during or right after a self clean cycle.You can confirm this by either measuring voltage at ignitor while oven is on.Alternate method remove ignitor ,check continuity, If the ignitor is coming on but no gas,replace ignitor it is weak.Hope this helps ,please take the time to rate my response :)
Feb 03, 2010 | Cooktops
Oven won't come on unless you press bake and immediately hit arrow to 400 degrees. Can this be fixed
Yes, this is most likely a thermostat problem. If you have tried every temp level below 400 and it will not come on until you reach 400 on the dial, then you most likely have a temp sensor switch/ thermostat problem.
I had to assume alot of things here:
1. It is an electric oven.
2. Once you get the oven to start at the magic number and try to dial down from there, the oven turns itself off.
3. It will start up as long as the temp is first set at 400 degrees or higher.
Jan 08, 2010 | Kenmore Cooktops
Stove top gas flow and gas oven bake cycle not igniting
This most likely is the solution for the bake problem you have:
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
Jan 05, 2010 | GE Profile JGP636 Gas Cooktop
Kenmore Elite 44173 30 in. Electric Cooktop Logo
290 people viewed this question
Top Kenmore Cooktops Experts
Michael Thomas
Michael Thomas
jdthefixer
k24674
Are you a Kenmore Cooktop Expert? Answer questions, earn points and help others
