Question about Panasonic KX-T7630 Corded Phone
Trying to change the message on the lunch mode on a panasonic kx-t7630
Posted by dunboynesurg on
Carl Navarro
  • Panasonic Master
  • 2,460 Answers
You can mess around in the Message Manager's mailbox and search for the custom greeting that contains the Lunch menu, but your Voice Mail installer should have left you specific instructions on how to change all greetings and custom service messages. As a minimum, you might give them a call and ask for a refresher in where those recordings reside in your voice mail system.
The Voice Mail be it a TVA or TVS, has a console program and password that will let you log into it and see where everything is located. The dealer should have provided instructions and passwords for administering the system.
Carl
Posted on Dec 02, 2010
Hi im trying to change the message setup when we switch the phone to night mode I cant seem to find any referance to this in the manuals i have it is a kx-t7630
The 7630 is just a phone. You have both a phone system and voice mail system and the message is located there. Find another set of manuals and WRITTEN instructions as to where the outgoing messages are stored. In a TVA voice mail system, they are changed via the message manager's mailbox #998.
Carl
Dec 22, 2010 | Panasonic KX-T7630 Corded Phone
Panasonic KX-T7630 the red light is on all the time as if i've got a messaage but there is no message. Nothing I do will turn the red light off.
Wow. Works for me. Try pressing MESSAGE and look at the display. The 3rd soft key will say "CLEAR". Keep pressing MESSAGE and CLEAR until the messages are empty.
Carl
Nov 04, 2010 | Panasonic KX-T7630 Corded Phone
Hi,can you explain how to assign and program phone to set to lunch/break message, and modify the lunch/break messages?
I could, but not in the "free" forum. You need access to both the TDA and the TVA systems. Once you get there, start reading the manuals. You need to assign a destination for Day/Night/Lunch/Break, a VM identity, then establish and record custom service menus or greetings for same.
If you go to the person who initially programmed the system, they should be able to guide you/do it.
Carl
Sep 30, 2010 | Panasonic KX-T7630 Corded Phone
Changing Panasonic KX- T7630 Business Phone Answering Message
You don't "lose" the manual, it comes on a CD. The Panasonic system probably has a TVA voice mail system and it requires you to change the Auto Attendant greeting from the message manager's mailbox. If you don't have the passwords for mailbox 998 and 999, you need to contact someone who has them and a layout of the system.
Your Panasonic technician can guide you through the process.
Carl
Apr 23, 2010 | Panasonic KX-T7630 Corded Phone
How do you switch out of night mode on the panasonic KX-T7630 phone ?
It may work on all phones, but from the main phone on the intercom dial *780x where x = 0/1/2/3 for Day/Night/Lunch/Break.
It can be programmed to work from any phones in the sysetm by class of service.
Carl
Dec 07, 2009 | Panasonic KX-T7630 Corded Phone
Instruction on how to divert incoming calls to a mobile.
hey c'mon please let the receptionist go after you have finished , why you want her with you?
May 20, 2009 | Panasonic KX-T7630 Corded Phone
How do you set the time
To change time on the KX-T7630 switchboard (using the TDA 100).
Press Progam or pause
Enter **
Enter your system password.
press cursor down one level - you will then see set date and time.
To exit the programming mode at anytime, lift the handset.
Hope this helps.
CM
May 19, 2009 | Panasonic KX-T7630 Corded Phone
Night switching for KX-T7630
You have 4 different modes of calling available to be programmed: DAY NIGHT BREAK and LUNCH. Your installer has to set up the ICD groups, but you can create a LUNCH group which looks like the day mode but rings all phones. The codes are accessed by dialing on the intercom *780x where 0 is day 1 is night 2 is lunch and 3 is break.
You may use the NIGHT mode in the daytime, but if you have voice mail, it will play the night greeting instead of a day greeting.
Carl
Sep 09, 2008 | Panasonic KX-T7630 Corded Phone
Night mode
I find that if you press line 24, you can scroll through Nigh Mode, Lunch Mode and Day Mode....Hope this helps
Dec 10, 2007 | Panasonic KX-T7630 Corded Phone
Panasonic KX-T7630 Corded Phone Logo
212 people viewed this question
Top Panasonic Lands Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Henk de Ruiter
Henk de Ruiter
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
