2002 Honda CR-V Logo
Anonymous Posted on Jun 26, 2008
Cd player not working
I do not have the manual to my used honda crv however when I push the cd button load or eject nothing happens is there a lock that could be stopping me
Marvin
Level 3:
Top Expert:
  • Honda Master 85,242 Answers
  • Posted on Sep 03, 2008
Marvin
Honda Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29058638
Points
266281
If it were locked it would ask for a code on the radio display, more likely the radio's CD changer is defective, they are very prone to failure.
CD stuck in my Honda Odyssey CD changer
Turn van off. Open & close drivers door, wait for everything to power down. Turn van back on and push button to close CD/Nav opening. It will close. Having an issue with CD player also.
I have a 2004 Mazda 3 w/ a single disc CD player...which has not been working for several months. There is a cd in the player but nothing happens when I press the eject button nor the CD button; won't...
Possible that the cd disc has jammed due to a change in the disc- warming can bend some cd's, also if the cd is struck inside as the loading mechanism is struck. In both cases the set must be pulled out if there is no hope with trying to retrieve the cd softly assisting while ejecting. If you do not hear any noise while the eject is pressed then the loading drive is faulty , you need to remove the cd , open to check, If this is mechanical then you can softly push the cd out, if not the electonic section needs a check.
Hi, this saturday i tried to change a cd from my honda civic copue 2006 stereo, but the cd didnt came out, it just made some noises and a message came up, mech error... please help!!! I push the eject...
If you gently push another cd in the cd player (not all the way but most of the way) it will either eject the cd or with your other hand hit the eject button and the other cd should come out. Mine did this but unfortunately it will not load cd's now so I don't if that made it worse or if it was already going downhill :(
I have a 2006 honda accord and the cd player unit
Replacing the CD player as it may have become defective and is cheaper to replace than repair
1helpful
Car CD player won't load Cd's - Peugeot 306
Yeah, the sensor that detects the presence of the disc is knackered - probably broken off. The eject will always eject the disc. Just press the button with no disc and you will hear it try. Look at ebay for a replacement - theyre dirt cheap!
1helpful
2002 Honda CRV factory radio - CD Plays but will not eject
mustangs do the same thing, on those if you swipe a credit card UNDER the cd while its ejecting it will come out, hope that helps.....
7helpful
3answers
Cd jammed in player
MY DAUGHTER PUT A CD IN THE CD PAYER AND NOW MY CD PLAYER DOES NOT WORK.I HAVE A 2005 NISSAN ALTIMA.THE KIND OF RADIO IS A BOSE 6 CD CHANGER.I PRESS THE CD BUTTON AND IT SAYS PUSH EJECT.I PUSH EJECT AND IT SOUND LIKE IT'S TRYING TO EJECT BUT NOTHING COMES OUT.CAN YOU HLP ME
Cd player won't turn on
ur vehicle needs a new stereo unit..
1helpful
How do I operate the multi CD player on a 2004 Honda Accord LX?
there should be a load button some where on the head unit
what for it to indicate that it is OK to insert another **** then press load again
to change disk there should be a disk button
to eject the cd just choose what disk to eject eg cd 4 then press eject
Top Honda Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Honda Expert? Answer questions, earn points and help others
