Question about Panasonic Lumix DMC-TZ3 Digital Camera
I have a Panasonic Lumix DMC-DZ3 Digital Camera bought 2 years ago, I like it very much as it is user friendly and the pictures are really great. The problem is one day, I on it and the screen is black, show no picture. However, if I replay all the pictures I took still show clearly. I wonder what happened to it, is it because the lens is broken?
Posted by hungswee on
Ty Price
    Brigadier General:
  • 11,967 Answers
Try these:
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Dec 02, 2010
Get photos off my panasonic lumix
Photo transfer from the camera to a computer is usually done with a USB cable. For detailed instructions on how to transfer the pictures, check out the user manual:
Panasonic DMC FX8 manual
Nov 21, 2013 | Panasonic Lumix DMC-FX8 Digital Camera
Just finished charging the battery of my Panasonic DMC-LX2. Attempted to turn on my camera but it doesn't work. The battery is completely charged and this has never happened before.
Hello....I have the same issue with my Panasonic Lumix DMC-FS5 camera we bought 3 years ago. All of a sudden the camera doesn't work. I have had many cameras and I have never seen this before. I will think twice about buying a panasonic again.
Dec 12, 2010 | Panasonic Lumix DMC-LX2 Digital Camera
How do I get quality pictures with the right settings
That's the beauty of digital photography. The pictures don't cost anything. Try your camera at different settings and examine the results. It's a great learning tool!
Aug 18, 2009 | Panasonic Lumix DMC-FX12 Digital Camera
CAMERA UNIT IS PANASONIC LUMIX DMC-FX33 MENU
It may be that for the type of picture you are taking the mode - dial at the top of the camera is not compatible.
Try a couple of different modes by adjusting the dial to auto, etc.
Apr 22, 2009 | Panasonic Lumix DMC-FX33A Digital Camera
Where can I find a manual for Panasonic Lumix DMC-FZ2?
Bro
Just download the DMC-FZ2 Instructions Manual/ User Guide from the following website. It's in detail, nearly 8 MB pdf.
http://www.ishots.net/fz1-2faq/
another helpful related pdf from;
http://fz1.alexoren.com/
Will answer in detail to questions that you dont even know yet ; )
Enjoy your great Panasonic DMC-FZ2 camera.
Jan 23, 2009 | Panasonic Lumix DMC-FZ2 Digital Camera
I've lost download software for my DMC-FZ8 [email protected]
You should be able to download your pictures with almost any graphics program. You can also use the program that came on lab lade disks a few years ago. You can try the manufacturer for a program, if you registered when you bought it.
Jan 08, 2009 | Panasonic Lumix DMC-FZ8 Digital Camera
A White Screen!
I had the same problem a few months ago. Best bet is take it to get it fixed. If you still have a warrantey it won't cost you a thing. Good luck!
Feb 29, 2008 | Panasonic Lumix DMC-FX3 Digital Camera
Panasonic DMC-FX7
It could be dirt/smudge creating the fuzzy on the left frame. Try having it professionally cleaned, or I am sure there are products you can buy on the market to do it yourself.
eg. a eye glasses cloth.
Nov 17, 2007 | Panasonic Lumix DMC-FX7 Digital Camera
Panasonic Lumix DMC-TZ3 Digital Camera Logo
879 people viewed this question
Top Panasonic Cameras Experts
STEVE SPAM REMOVER
deton8 von Splosion
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
