Paragon Drive Copy 9 Professional Corporate License  Logo
Anonymous Posted on Dec 02, 2010
Error code Ox12015 The restart operation that has been requested now, cannot be performed under the 64-bit editio nof windows. Please use a recovery CD for this purpose.
  • Anonymous Dec 02, 2010
    What the heck kind of answer is this to my question?
Joe Brady
Level 2:
Sergeant:
  • Expert 300 Answers
  • Posted on Dec 02, 2010
Joe Brady
Expert
Level 2:
Sergeant:
Answers
300
Questions
6
Helped
45749
Points
909
That is an illegal pirated cracked junk. you should pay for a new software.
Tried a f11 factory recovery with unsuccessful loading of win7, error reads, must reinstall win7, but the recovery petition will no longer respond. HELP..
Make sure your installing the right windows either 32 or 64 bit windows.you can't install a 64 bit system on a 32 bit if it doesn't support it.
Missing partition
there are many freeware data recovery programs available on the web
http://download.cnet.com/easeus-partition-recovery/3000-2248_4-75279786.html
Easeus Partition Recovery is a free and easy to use partition recovery solution. It can solve the partition loss problems including partition deleted by accident, partitions lost due to virus attack, partitioning error or any other problems under Windows both 32 bit and 64 bit operating systems
hope it helps
How do i reboot toshiba without the cd
Hello, please follow the step,
Toshiba System Restore Vista Step 1 - "Initiating the HDD recovery procedure"
1. Switch on the computer and press "F8" key while Toshiba logo appears. You will see the following screen.
Choose the entry "Repair your Computer" and press "Enter":
2. Wait till the following screen appears, choose the keyboard layout which matches the language of your keyboard and click on "Next".
If unsure, just click on "Next".
3. the following screen a window with your username appears.
Type your windows password as you would log on to your account and press "OK":
4. The next screen offers several options to repair or diagnose your computer system.
To start the recovery, click on "Toshiba HDD Recovery":
Step 2 - Performing the HDD recovery
1. After passing the previous screen, you will be asked if a backup of your important data is already made.
You can continue with the recovery process by clicking on "Next"
2. Confirm the following screen also by clicking on "Next"
3. You will be asked again if you want to recover your machine (and delete all files on your harddrive).
There are no additional options regarding the harddrive, which can be set. Click on "Yes" to start the recovery.
4. The recovery procedure starts immediately by formatting the harddrive and copying all needed files to the harddisk
5. By pressing the "Restart" button to restart the machine, the recovery procedure is almost finished
Step 3 - Finishing the recovery process
1. After the successful completion of the recovery process and the restart of your machine, the following screen should appear.
2. The installation wizard of Windows Vista / Windows 7 will start up to guide you trough the setup for your newly installed system and to finish the installation of the operating system
FOR WIN 7 Toshiba System Restore Windows 7
How to recover a Toshiba with the HDD recovery procedure
- Operating System: Windows 7 - 32 Bit, Windows 7 - 64 Bit, Windows Vista 32 Bit, Windows Vista 64
Bit
The following guide describes how to recover a Toshiba with a preinstalled Windows windows 7 from HDD through the
"HDD recovery procedure".
Please note:
First of all, make sure you already back up your important data!
1. Switch on the computer and press "F8" key while Toshiba logo appears. You will see the following screen.Choose the
1. Wait till the following screen appears, choose the keyboard layout which matches the language of your keyboard and
click on "Next".
1. In the following screen a window with your username appears.
1. The next screen offers several options to repair or diagnose your computer system.To start the recovery, click on
1. After passing the previous screen, you will be asked if a backup of your important data is already made.You can
1. Confirm the following screen also by clicking on "Next"
1. You will be asked again if you want to recover your machine (and delete all files on your harddrive).There are no
1. The recovery procedure starts immediately by formatting the harddrive and copying all needed files to the harddisk
appear.
1. The installation wizard of Windows Vista / Windows 7 will start up to guide you trough the setup for your newly
Hope this helps,
Hope this helps,
Going from 64 bit to 32 bit on Windows 7
Ill make a big assumption here : On the bottom of your laptop there is a license key - That Key will tell you which kind of opertaing system you'll have on the hidden partition and it just might say 32bit or 64bit.
Nevertheless, disregard the top part here if it does not. Restart your Laptop, keep pressing ALT and F10 together continuously after the Acer Logo until it says somemething like "Windows is loading files". It should then give you onscreen instructions - and it might just also give you the option to choose which operating system type (32/64) you want.
On another model or also others, the Recovery DVD's that come with the laptop contain this option i know for sure. When pressing F12 on startup, (if the F12 boot menu is ENABLED under "advanced tab" in the BIOS) you can choose a device to boot up from ; Choose the DVD drive and boot from your recovery DVD - When it's done loading, you should be able to choose the operating system you would like to restore on your laptop.
Last but not least, if you have a Windows 7 Installation Disk, it will prompt you for choosing 32bit or 64 bit respectively. If you have lost the original recovery DVD's, you can request them from Acer.
Hello i am using windows 7 64 bit & i am facing trouble in playing videos of youtube. please give the solution to it thanks
I would like to inform you that, Adobe flash payer is not compactable with 64 bit Operating system. However, in 64 bit operating system you will get the 32bit and 64 bit internet explorer. Hence, I request you to use the 32 bit internet explorer and it will resolve the issue.
To use the 32bit and 64 bit operating system I request you to follow the below steps :
There are actually two shortcuts for Internet Explorer in the "All Programs" menu. Why two and what's the difference?
Here's the title of each and the exe's they run:
Internet Explorer
"C:\Program Files (x86)\Internet Explorer\iexplore.exe"
Internet Explorer (64-bit)
"C:\Program Files\Internet Explorer\iexplore.exe"
The first one runs IE from the "Program Files (x86)" folder, this is the 32-bit version. The second one is the 64-bit version.
3answers
1helpful
2answers
WindowsXP-KB835935-SP2-ENU-exe is not a valid Win32 application
Hi, It seems that you have downloaded the wrong version of the software. However, to know which bit version of you are using, perform the below steps: Method 1 1. Click Start, click Run, type sysdm.cpl, and then click OK. 2. Click the General tab. The operating system appears as follows:? For a 64-bit version operating system: Microsoft Windows XP Professional x64 Edition Version < Year> appears under System. ? For a 32-bit version operating system: Microsoft Windows XP Professional Version< Year> appears under System. Method 2 1. Click Start, click Run, type winmsd.exe, and then click OK. 2. In the details pane, locate Processor under Item. Note the value. ? If the value that corresponds to Processor starts with x86, the computer is running a 32-bit version of the Windows operating system. ? If the value that corresponds to Processor starts with ia64 or AMD64, the computer is running a 64-bit version of the Windows operating system. If you have downloaded the correct software, then perform the below step: Right click on the file WindowsXP-KB835935-SP2-ENU-exe and select properties and select properties. Click on Compatibility tab and check "Run this programs in compatibility mode" option and in the drop down menu select Windows NT 4.0 (Service Pack 5). Then click apply & Ok. Then restart the computer to make the changes effective. Hope this should resolve the issue. With Regards Mike.
Top Paragon Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Paragon Computer and Internet Expert? Answer questions, earn points and help others
