Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
Posted on Dec 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I forgot my pass key to connect my laptop to the router and i lost the instalation cd how can i put another password?
Rakesh Warrier
Level 3:
  • Master 708 Answers
  • Posted on Dec 02, 2010
Rakesh Warrier
Master
Level 3:
Answers
708
Questions
0
Helped
209467
Points
1609
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
3answers
When i put the laptop on there is a password it be on the sytam
Forgot windows password,four steps can help you reset the lost Windows 8/7/Vista/XP/2008/2003/2000 password:
Step 1: Download Windows Password Reset
Step 2: Burn bootable CD/DVD or USB flash drive
Step 3: BIOS setting
Step 4: Reset Windows password
I can not log onto my zoom router.....forgot my pass key for network need to add laptop
1. You will have to reset the router to factory default and run the setup wizard using your set up CD and create a new key.
Set up your laptop on the router using either the MAC address or a new password key.
1.Log into router
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP adresses.
5. Set the laptop up in the router by WEP KEY or MAC address.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
2helpful
2answers
Lost password/unknown security key
Connect your laptop to router using ethernet cable open internet explorer & type 192.168.0.1 press enter it will take to login screen and if you havent changed the username and password for the router it should be admin as the username and password as password. once in the router you can change the network key to anything as desired by you.
2answers
Password for the Linksys Wireless Router
Power down the linksys and on the back is a reset button push it. The ones i have installed dont need a pass word or key,if it is asking you try the info you used from your internet provider ( e-mail address or access #s)Also try skipping this step and see if it will let you go on to the next part,Lynksys advisor has major issuses with it I dumped it from all the pcs I installed.
1helpful
2answers
Forgot password
To ilysurita, cj_mom, top_shutta…
First can I clarify what is meant by a ‘lost password’ …. The original poster here is asking about the password needed to login to the router configuration pages.
If you know the password to login to the router configuration pages, you can still get access to the network key (also known as passphrase, WPA or WEP key, PSK, pre-shared key) – which is the key Windows asks for to connect a new computer to the network. It will be found under a heading like ‘Wireless Security’ or ‘Wireless Settings’ within the router configuration pages. For this model, you can find the router configuration pages by typing www.routerlogin.net (or .com) into a web browser, or http://192.168.0.1
If you don’t know the username/password to login to your router, try using the defaults – for this model, they are admin and password.
However, if the router login username/password has been forgotten, the only way to regain access to the router configuration settings is to reset the router, as described in my posting above. I don’t know of any shortcuts to this one. :(
If you have to resort to this, you might want to wait for whoever set up the router to help with this. This is because resetting the router will remove all your settings – password, network key, ISP connection info – so you will lose your internet connection altogether until it is set up again.
On the other hand, if you’re willing to spend some time and patience, you can have a go yourself.
If you have your original setup CD this may contain a software wizard to walk you through it. If not, you might be able to download a setup wizard from the router manufacturer’s website, along with a quick installation guide (and a manual).
The Netgear site also has very clear troubleshooting and support pages which will help with setup, even if you don’t have any setup software:
http://kbserver.netgear.com/products/wgr614v9.asp
Make sure you use a wired connection. Also, print off all the information you need before you begin, as you will not be able to access the internet while you are setting up the router.
Good luck whatever you decide to do
1helpful
2answers
How to get password key
WEP password is on botom or on the side of the router
Forgot my password for the cd
If you forgot the password for the router, what will be your next option is to reset it back toi default settings and run again the setup CD for the router, To reset it Press and hold the reset button for 15 seconds while the power is ON then after that you can now run the setup CD for the router and its back to admin as the default password.....
Pass key for a new laptop
go to this site and download SIW (third one down in left freware list) and install it on the pc that already connects, it's aprogramme that allows you to see everthing listed on your pc including passwords.
when installed on the left column is secrets, click on this and you will see your router passkey listed, enter this key on your other pc.
2answers
Forgotten pass word
If you are meaning the password to connect wirelessly then just reset the router by pressing small reset button. Then us the password/key on router to connect.
If you are meaning ur password to get router to go online you will need to contact your ips for that.
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
