Question about Bose Wave radio/CD remote control - Graphite Gray Shelf System
How to set alarm time on bose wave radio - Bose Wave radio/CD remote control - Graphite Gray Shelf System
Posted by lamont01lamo on
Randy Hough
    President:
  • 2,559 Answers
To set the Alarm 1 time - On the control panel, hold down ALARM
SET and press TUNING up or down. The time display changes slowly at
first, then more quickly. Release TUNING to stop.
On the remote, press TIME. The ALARM indicator flashes. Press
TUNING up or down. The time display changes slowly at first, then
more quickly. Release TUNING to stop. Press TIME to return the display
to the current time.
To turn on the Alarm 1 function - Press ALARM MODE or
ALARM in sequence to select the mode you want: tone, radio,
both tone and radio, or off.
For tone only, press until the indicator lights.
For radio only, press until the indicator lights.
For tone and radio, press until both indicators light. When the
alarm goes off, the tone sounds. Press SLEEP/SNOOZE to turn the
radio on. Press SLEEP/SNOOZE to pause the radio for 10 minutes.
To turn off the Alarm 1 function - Press ALARM MODE or
ALARM until the display shows no Alarm 1 mode indicators.
To check the Alarm 1 setting - On the control panel, hold down
ALARM SET to see the wakeup time.
On the remote, press TIME to see the wakeup time. Press TIME again to
return the display to current time.
To wake to a preselected radio station with Alarm 1 - While
holding ALARM SET, press the PRESET button for the station you want
(change between AM and FM if needed).
Posted on Dec 02, 2010
How to set and remove alarm set
Turning on/off the alarms
To turn alarm 1 on/off, follow these steps:
  1. Turn the system off
  2. On the radio, repeatedly press the Alarm Mode button until the desired alarm mode indicator below "Alarm" is displayed. The music note indicates radio and the sound waves indicate the alarm tone. If no icons appear on the display, that means the alarm is turned off
wr_alarm_set_icon_both.gif Radio and tone
Radio only
Tone only
Alarm off
To turn alarm 2 on/off, follow these steps:
  2. On the radio, press and hold the Alarm Set button. "Alarm" flashes on the display
  3. While holding Alarm Set, press the Alarm Mode button once. "Alarm 2" flashes on the display
  4. Release Alarm Set, and repeatedly press Alarm Mode until the desired alarm mode indicator above "Alarm 2" is displayed. If no icons appear on the display, that means the alarm is turned off. The "Alarm 2" indicator will continue to flash on the display for 10 seconds. When the flashing stops, alarm 2 is set
wr_alarm2_set_icon_both.gif Radio and tone
Radio only
Tone only
Alarm off
Jul 20, 2014 | Bose Wave Radio
Wave radio comes on randomly
Random is truly a difficult problem to solve, if no pattern of failure can be detected. It sounds as though the alarm may be at fault. Is the alarm on and set to radio, CD, or beep? If radio, that could pinpoint the problem. If you have another, mechanical alarm, use it for a couple nights with the Bose Wave alarm off. If the Bose still acts up, then it isn't the alarm. Try unplugging the unit, waiting at least 30 seconds, and plugging it back in, which will cause you to need to reset the alarm. Alternately, remove the Bose cover and blow out dust. I find the Bose susceptible to dust as a cause of malfunction, which may point to the cause being the compact design of the unit. Good luck.
Jul 09, 2013 | Bose Wave Music System CD Shelf System
How to turn off second alarm
This is a picture of the Bose Radio Wave part of the manual that explains how to Turn Off the Second Alarm. And I added too the link for the page where you can find the original manual.
http://products.bose.com/pdf/customer_service/owners/wrv3_guide.pdf
Mar 12, 2013 | Bose Wave Radio
I want to change from military time to regular time on my Bose wave radio. I already tried holding down the alarm set button and on/off button but it didn't work
Page 18
http://www.retrevo.com/support/Bose-Wave-radio-Radios-manual/id/525bh044/t/2/
To set AM/PM (12 hour) or Military (24 hour) time - Press the On/Off button once to turn your Wave radio off.
Press and hold Clock Set, and then press On/Off to switch between AM/PM (12 HR) or military (24 HR) formats
Jan 27, 2011 | Bose Audio Players & Recorders
I can't seem to adjust the time using the remote
You can obtain the Bose Wave radio instruction manual in electronic form, here: http://products.bose.com/pdf/customer_service/owners/og_wrcd.pdf
See page 15 for setting the time. You should be able to do it with the unit controls.
Apr 13, 2010 | Bose Wave Radio
My 10+ year old Bose wave radio/alarm on fritz
Replace the 3 AA batteries that maintain memory & backup alarm function. That just may do the trick.
Apr 10, 2010 | Bose Wave Radio
I have a bose wave model awrc-1g cant set time from military time to regular
Hold the alarm setup button and at the same time hit the on/off button.
Oct 16, 2008 | Bose Wave Radio
Setting time
On first generation Bose, press "Alarm Setup" and "on/off" button to toggle between military and 12 our time.
Older model documentation:
http://www.bose.com/pdf/customer_service/owners/og_wrcd.pdf
May 29, 2008 | Bose Wave Radio
Military time
I have the same problem. The clock changed to military time after we experienced a power failure. I have tried to correct it by holding down the "Alarm Set" button and hitting the "On/Off" button at the same time. It works while the buttons are pressed but immediately reverts to milirtary time. Any other suggestions?
Mar 30, 2008 | Bose Wave Radio II
Clock on Bose Radio
Push & hold Clock Set Button. While holding, push On/Off button,
Thank You, FixYa Community! Thank you! Thank you! Boy, that one was not obvious.
Nov 06, 2007 | Bose Wave Radio
956 people viewed this question
Top Bose Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
