Jason, MOST refrigerators get there cold from the freezer side and circulate it via a fan that's also normally inside the freezer. There are three motors normally in a refrigeration system. The inside Evaporator fan motor that circulates air across the evaporator coil inside the box, the Condenser fan motor near the compressor that cools the freon after compression, and the compressor itself. If you open the doors (and sometimes you may have to hold in the door switches) do you hear a fan running? If not you could have a couple things going on: 1. The fan(s) has failed. 2. The freezer Evap coil may of iced over and the fan too is frozen stopped. 3. Your condensing unit:(compressor, condenser fan, condenser coils) has a problem. It is important to know if the compressor itself is running. If there is a loose connection to the compressor via the start/over load relay (normally attaches directly onto the compressor), or if the start/over load otself is bad the compressor will not run. Best way to tell is via gauges but I doubt your frig has ports. Check to see if your compressor is really hot. Could be bad start/over load relay or bad compressor. Try unplugging your frig for say 30 min then, with your hand on top of a cool compressor, plug the frig back in and see if compressor smoothly vibrates for at least 5 min without becoming very hot or shutting off even though fan continues to run. The fact your fan is running TYPICALLY means the thermostat is calling for lower temps and the fan/compressor kick in together.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp. The problem could be the electronic control if you have one or the mechanical linkages.
it.There is a flap you adjust with the
fridge temp.
If the evaporator coils behind the back panel of the freezer
are icing up because of auto defrost failure that will stop the circulation of
cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In
most newer models the timer has been replaced by an electronic control board.
If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks
and everything shuts down. The heater should now come on. If it does, replace
the timer. If it doesn't, check the heater and defrost thermostat. Turn the
timer again till everything starts back up to end the defrost cycle.
I did it without spending a dime! I found a REAL site that directed me to the problem and sure enough that was it. Nice SCAM you got going here. I'm unsubscribed from you, and any further scams you may try to bait me on!
The fan that is under the frig is the condensor fan(the fan the cools the condenser coils and the compressor. It does not have a direct effect on the chilled air circulation inside of the frig. The evaporator fan is the unit that circulates the chilled air thru your freezer and frig. I am not sure what make model unit you have, but I have found that this fan motor is 90% of the circulation problems i have seen.
Check the door seals to be sure they are in good working order. Close both doors on a dollar bill at several locations all around the door and pull on the dollar bill. You should have resistance as you pull it out in every area you check. If you have any gapped areas and it slides easily, adjust the door or replace the seals. Also, is the circulation fan in the freezer working correctly? Lastly, unplug the unit for 5 minutes to allow the control module to reset itsef. Then plug it in again and reset your temps, clock etc.
Is your freezer below your frig, like a drawer. If so does it still freeze the food. if this fact is true, then listen with the freezer drawer open to hear if the freezer fan is running. If it is running and your freezer is working then it could possibly be that fan that is the problem. This fan circulates the chilled air from the evaporator coil thru the freezer and the refrigerator. This problem is very hard to diagnose as the fan still spins but not fast enough to circulate the chilled air thru the freezer and frig. The minimum cost is around $300.00 if a service company does it. But if you can do it then you can possibly get the fan motor for around $80.00. This repair is very labor intensive as the access to the electrical connection is at the extreme rear of the freezer compartment.
Is the freezer cold enough to make ice maker operate. 10 degrees or less.
fridge temp .
you might have a few problems,, make sure to check the condensor is clean, also make sure the condensor fan motor is going... you might have a bad Condensor fan motor, and Ref Control or a Freon Leak @ the Evaporator... I would call a tech to check it out...
