SOURCE: TV ranking
Hi. You could look up reviews. I personally usually never offer advice on choices, because what I like, may not be what you like..its a matter of personal preference. But in this particular case, I'd go for Panasonic. Why? Better features, better service, easier availability of parts, and better resolution.Plus some nice features. If this answers your question, PLEASE don't forget to rate as fixed. I'd really appreciate it. Enjoy your new tube!!!
Jeff
SOURCE: just set up Vizio 32 LCD HDTV with HDMI connection - no sound
Nope, HDMI is all in one. Video and Audio.
SOURCE: Vizio L32 32 in. HDTV LCD HDMI input not working
I recently had the same problem with my vizeo hdmi port # 1 going bad. Tried everything to fix and called vizeo. There solution for a master reset was turn off tv and unplug from the wall. then hold down the power button for 30 secs and let go. plug the tv back in and hold down the volume down and input select buttons down on side of the tv for 15 secs. release the buttons and turn the tv on after powering down all the components connectd to the tv. If this does not work they told me you need to have it sericed for a bad hdmi input. Hope this info helps anyone out there. It didn't work for me. Its a bummer cause the tv is well taken care of and only 18 months old. Best of luck to all others.
SOURCE: Purchased and set up both Vizio SV370XVT HDTV and
Try setting your cable box for Closed Captioning. Worked for me.
SOURCE: I have a mfg date 2007 Vizio VW37L HDTV10A turned
This can happen. are the lights on? if not, it most likely id the power source inside the tv itself. make sure your wall outlets are working properly as well, but if they are, then you want to get you tv fixed. this can be a relatively low cost repair, but shop around
http://download.cnet.com/Realtek-AC-97-Driver-Windows-Vista-Windows-7/3000-2120_4-10962344.html
Update your embedded sound from Realtek to the latest AC'97 codec.
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or you can download the drivers
Download the driver software by
http://download.cnet.com/Realtek-High-Definition-Audio-Codec-Windows-Vista-Windows-7-32-bit/3000-2120_4-10788600.html free sound drivers
using this link you will be able select your drivers
hope this helps
http://download.cnet.com/%7Bvalue=http://www.download.com/realtek-high-definition-audio/3000-2120_4-75317047.html
Realtek HD audio driver package. The package includes: driver setup program, drivers for Windows Vista / 7 64-bit
http://www.freeware-downloads.com/soundmax_integrated_digital_audio_driver_v.htm
SoundMax Integrated Digital Audio Driver v hope one of these helps
Realtek HD audio driver package. The package includes: driver setup program, drivers for Vista 32-bitedition. http://download.cnet.com/Realtek-AC-97-Driver-Windows-Vista-Windows-7/3000-2120_4-10962344.html
Realtek AC'97 audio driver package. The package includes: driver setup program, drivers for Vista/Windows 7 32-bit and 64-bit editions.
hope this helps
hope this helps
hope this helps
