Question about Haier HBF05EBSS Commercial Beverage Dispenser
I have a 2 year old Haier kegerator and it seems to have stopped working. I hear a clicking sound which I believe is the compressor going on and off. I have done some research and found that this is a common problem and some say that it may be the relay/overload protector. I examine mine and the overload protector on mine is a P6R8MD and the Compressor is a LG MA53LBCM. Now for the question, What do I do, How do I fix it ? any suggestions ?
  • 1 more comment
  • Anonymous Dec 09, 2010
    i do have some technical background, what do you suggest
  • spotter740
    spotter740 Jan 14, 2013
    i see where I guy mentioned the compressor getting hot means it is shot, is this correct? Would still get the clicking sound?
  • Noel Padilla
    Noel Padilla Apr 21, 2014
    Here's a quick video to help with troubleshootinghttp://youtu.be/QwOusnykwA8
Brad Jensen
  • 130 Answers
Do you have any technical background? There is a simple and sure fix to this but you will need to be able to read a wiring diagram and have basic electrical tools like a wire stripper and electrical tape.
Posted on Dec 02, 2010
  • 3 more comments
    I have the exact problem with the same parts, and yes, i have some technical background. Any help would be appreciated.
  • Brad Jensen
    Brad Jensen Dec 20, 2010
    Sorry i didnt answer sooner, my email marked this as junk and i didnt see your reply. Anyways, you will need to wire in a 3 in 1 to the compressor. You can order this part at Reliableparts.com, using your model number. It cost around $20 and has a picture of exactly how to wire it in. The part number is URCO410
  • Anonymous Dec 20, 2010
    Thank you, I already did order that part and installed it. The kegerator is up and running again
    thanks again. it wasn't as hard as I thought to install
  • kdeho85 Jun 03, 2012
    could I just order the replacement tertiary our do I have to get the 3 in 1.. I am having exact problem
    Replacement *relay
I have a Haier kegerator,just had someone put in freon beer is cold, but the line coming off the compressor that goes up into the cooler part is freezing up
this indicates that liquid is evaporating in the suction line to the compressor
that indicates that the unit has excessive gas and is not working as well as it should
have the gas checked by a professional refrigeration technician
Sep 30, 2016 | Haier Refrigerators
Not starting
ck that you are getting power to it some of them have fuses on them , the switch may be bad
Mar 28, 2014 | Haier Kegerator HBF05EBSS Draft Beer Tap...
TDD 2 Kegerator clicking and not cooling?
It's extremely rare that the compressor will be any good. Usually replacing the start relay does nothing on these small units. If you know how to use a multi-meter and are any good at wiring the cheapest way to go is to get what is called a 3-in-1 start kit at a HVAC wholesaler. You need to know the model of the compressor and/or the horsepower to get the right one. I would recommend getting a service tech to look it over though. Most likely the compressor is locked up.
Nov 16, 2012 | True Direct Draw Systems: Kegerator TDD-2
Water cooler stopped working
Compressor seized, may just need a new start relay or capacitor
Aug 07, 2012 | Haier WDNS32BW Hot Cold Water Cooler With...
Does the Fan on a Haier HD456E always run,
I believe the fan is designed to run all the time, and no, it costs very little to run an 18w fan. You can use a timed socket, or switch it on and off when needed. I don't believe the Haier has specific switching times.
Apr 16, 2012 | Haier HD456 Dehumidifier
Had the compact refrigerator for about 4 years now,then it suddenly stopped working.all I hear is a click sound about every ten minutes. Mode; # ASE27W, need assistance......HELP!! I Love my compact refer.
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. The relay is a small usually black cube shaped electrical part plugged into the compressor or wired to it nearby. It may appear burnt or rattle when shaken if it's bad. The two connections should show continuity with an amp meter. If it's good then it's most likely the compressor causing the problem.
May 25, 2011 | Haier Refrigerators
Beverage-Air Kegerator Not Staying Cold
It can take a very long time to get a keg of beer down in temperature. The heat transfer from a keg is slow due to the lack of air circulation inside the keg. You should also check your condenser coils, make sure they are clean. Door gasket should also be in good repair. Hope this helps.
Jan 20, 2009 | Beverage-Air Kegerator - Beer Keg Cooler...
Fridge won't run
hi brenda,
can u hear a humming sound as if it is trying to start then it would stop after a clicking sound?
if it does then it is your compressor trying to start but can not do it.
you could either have a problem in your starting relay of overload protector of the compressor or the compressor itself is the defective part and it needs to be replaced.
i hope i was able to help.
pls rate me
tnx
drcool
Jul 21, 2008 | Magic Chef MCBR440 Compact Refrigerator
GE HSS25GFP not cooling at all
May be a problem related to the compressor. Click may be the overload protector on the compressor tripping. If it is a problem with the compressor it should be covered by warranty if it is only three years old.
May 14, 2008 | Hotpoint HSS25GFP Side by Side...
Haier HBF05EBSS Commercial Beverage Dispenser Logo
2,521 people viewed this question
Top Haier Refrigerators Experts
Vernon Taylor
John Tripp
John Tripp
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
