Hello and Welcome to FixYa!
You have to update / reprogram the phone's firmware, it is easy for an End User, all you need is the USB Data cable of your phone, if you have it then proceed, if you didn't have one then do note, there is no code or something similar to format the SE phone, don't get fooled by anyone. I've done is many times, so I'm telling you on the behalf of my experience. This is a famous issue with SE phones called WSOD (White screen of death).
Ok now if you got the cable, download the Update utility from the link I've provided below, all you have to do is to download the utility, install it and run the application, it will automatically check for updates and then the wizard will guide you accordingly on how and when to connect the phone. Its easy and I'm 99% sure this will resolve your problem, the 1% is reserved in case there is some hardware issue.
If you are having any questions/issues do ask me. I'm here to help.
If you think I was of help, your token of appreciation in the form of rating will be esteemed.
Concerned, Nooh
P.S: Sony Ericsson K610i update utility
or:
For soft reset type *#7780# For hard reset type *#7370# and if it ask passcode enter the passcode as 12345 as default.Please backup all your data if you performing hard reset because hard reset deletes all data on your phone like contacts,messages,music,videos and phone
SOURCE: Sony Ericson k610i sloution need
Go to SonyEricsson Service center, than tell Ur trouble Ur phone
SOURCE: How could i set Gprs
Welcome to
General Packet Radio Service (GPRS) is a packet-based
wireless service used for sending and receiving data through the internet
protocol. With GPRS, the transmitted data is divided into various 'packets'
before it is received by the user.
Setting up GPRS for your phones:
Usually activating GPRS on your phones are done by the service
providers, and different service providers have different configurations.
Additionally, the settings for GPRS vary based on the different phones and phone
models. As activation is required before setting up you should know that
activation process vary from one provider to other. It could be as simple as
sending an SMS to a particular number or calling customer care of that
particular service provider. Once the activation is taken care of, the setting
of the GPRS is done based on the model of the phone.
It is
important to note here that the setting for GPRS is different for different
phones companies and may be different even for the different models produced by these companies.Therefore, it is recommended that you rely on the information
given directly from the service provider. Again activation process may be
different for postpaid and prepaid customers. So
just call and demand GPRS settings for Sony ericson k610i by the service provider, They will send it
free
I hope this solution will helpful for you
Thanks and Keep Using FixYa
