Question about Kohler 12 kW Emergency Power System - 12RES-L
Can some one tell me what oil and air filter to buy for a Kohler 12res LPG generator?
Posted by Kent Vickers on
  • Dale condos
    Dale condos May 30, 2014
    Use Koehler filter 12 050 02-s filter and a good 10/30 oil,you have to use 10/30 oil because some Koehler engines have hydraulic lifters.
wglisk
    New Friend:
Kohler Model 12RES generator manual calls for use of synthetic oil (Mobil 1 or equivalent) as follows: If temperature is normally above 0 degrees F, use 10W30. If temp. is normally below 32 degrees F, use 5W20 or 5W30. NAPA Auto Parts recommends their #1056 oil filter for the 12RES.
Posted on Sep 06, 2012
dan turkstra
    New Friend:
  • 44 Answers
Lowes sells air filters for Kohler engines . As far as the oil a SEA 30 or 10w 30 would be fine.
Posted on Dec 02, 2010
  • MickFromMain Sep 01, 2011
    Not all Lowes (or Home Depot) carry oil and air filters for Kohlers. You might try any of the auto parts stores. They can look up the proper filters for both oil and air using their Fram (or alternative) cross-reference charts. Although you didn't ask about what oil to use, I would recommend a synthetic 5W30 or 0W30 if you are in a cold climate.
Trying to find what oil filter can be used in 14KW Kohler
what is the filter part number on the Generator now? Give that to an Auto parts place and they will cross it to what they sell
May 05, 2015 | Kohler Electrical Supplies
Trying to find oil filter that can be found locally from car part supply store.
take the old filter along to the spares shop and see if they can match it up
I suspect that the same filter will fit both engines
if you want to get technical, use a verniers to measure the thread hole diameter, a thread gauge to get the thread pitch, and the outside diameter of the oil seal
by going to oil filters manufacturers on line and researching their catalogues you will find pages of filters with dimensions that will match you filter
I would rather just go and buy a genuine filter from a mower shop or kohler dealer as there may be a generic filter already listed.
May 05, 2015 | Generac Electrical Supplies
MY YAMAHA 6600DE GENERATOR STARTS AND DIES WHAT COULD BE THE PROBLEM
this sure sounds as if the low oil cutoff is activating for some reason , look at switch carefully to see any physical dammage (ck oil level as well)
May 21, 2014 | Kohler 12 kW Emergency Power System -...
I have kohler 12res 60hz generator can I covert to 50hz ? If yes than how can ?
No you cannot, a 60HZ unit is designed to run (and the controller expects to see 60HZ) RPMS 1800 for a 4 pole rotor and 3600RPM for a 2 pole. Slowing engine speed down to 1500RPM the controlelr would see it as under frequency
Mar 29, 2013 | Kohler 12 kW Emergency Power System -...
Kohler 12RES only starts on second try
Check gas pressure. Oc is over crank. Means tried to start but did not.
Nov 25, 2012 | Kohler 12 kW Emergency Power System -...
Generator won't start. Screen showing OC.
OC means OVERCRANK safety circuit stopped the auto start-up so you wouldn't burn up the starter. There is a reason the generator didn't start. Low battery, not enough fuel pressure, clogged air filter, bad starter... You just have to eliminate as many as you can visually. Rebooting the generator should clear the OC condition and you can try to start it manually.
Oct 11, 2010 | Kohler 12 kW Emergency Power System -...
I have a Kohler 12RESM1 propane generator with oc/uu code
U need to make sure that the relay driving ur auto start stay closed all thru the crank cycle.
Feb 04, 2010 | Kohler 12 kW Emergency Power System -...
Kohler Confident 7 model 7CCKM22 generator
sounds like a relay should be latching one it has started
UU undervoltage kohler 20kva
call koler but ui think is meant high heat as in the thermal circut is shuting you down or low oil
could be a couple of things best bet call kohler
Aug 06, 2009 | Kohler 12 kW Emergency Power System -...
Kohler 12 kW Emergency Power System - 12RES-L Logo
506 people viewed this question
Top Kohler Electrical Supplies Experts
Sheldon Dedek
Tim Venetis
Marvin
Marvin
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
