Question about Weiser Lock GED1460X3BR Lifetime Polished Brass PowerBolt Powerbolt Touchpa
We lost the directions how do you change the code and how to get the back off
Posted by ingrave on
Coaltowner
  • 963 Answers
Here's a link which tells you how to remove the cover, and reprogram the lock codes:
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
Posted on Mar 05, 2011
Lost code & key
you should be able to get the key and code provided it was never changed from the company directly here is a link to the company's support page where you can use that serial number and lock code to get the things you need
http://www.mesasafe.com/technical-support/contact.html
Lost directions on uniden cordless phone DXAI8580-2, unable to access message as code using does not work????
If you mean the PIN for remote access, that's a two-digit number. If you've forgotten what it is, you can change it at the base station by following the instructions on page 12 of the manual.
If you mean the messages on your telephone company's voicemail system, try dialing *67 (that's star-six-seven). If that doesn't work, contact your telephone company for instructions on accessing their voicemail system.
2answers
Lost remote and can't change the input
They sell basic RCA remotes at places like Walmart for about $5.
4helpful
2answers
SILVER RC24922-C LOST CODES FOR TV AND DVD
Most universal remotes will drop the code memory if the batteries have been out for more than 1 minute - you will need your instruction sheet to reprogram, this will have the codes too.
If you have lost the sheet then google the remote model number
4helpful
I lost my code sheet and I need the code for a Symphonic TV
If your product does not respond after you have tried all
the codes for your brand, or if your brand is not listed,
try searching for your code by following these steps.
1. Manually turn on the device (TV, VCR, etc.) to be
controlled.
2. Press and hold the CODE SEARCH button until the
red indicator stays on, then release the CODE
SEARCH
button.
3. Press and quickly release the desired mode button
(TV, VCR, etc.). The red indicator blinks off once.
4. Press the CHANNEL UP button repeatedly (up to
300 times) until the device to be controlled changes
channel. The red indicator blinks off with each
button press. If you accidentally overshoot the
code required, press the CHANNEL DOWN button
to backtrack through the library until the device
changes channel. Pressing CHANNEL UP changes
direction to forward again.
5. Press and release MUTE to install the code.
Most users will store VCR codes under the VCR button,
Cable codes under CABLE, etc. If (for example) you
want to store a VCR code under CABLE, first follow the
procedure for Direct Code Entry (previous page) and
press CABLE in step 2 of Direct Code Entry, then enter
ANY VCR code in step 3 of Direct Code Entry. Then
follow the steps above for Code Search (or Brand
Search, below). Note: If the device does not have a
CHANNEL UP button, use PLAY (VCR only) or
POWER instead. Code Search starts from the currently
stored three digit number under that mode. Good Luck.
1helpful
Lost remote programing directions
Great News!! We can program most Philips Universal Remotes with Automatic Code Searh. Here's how it works on most of our remotes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
The above assumes that you want to store the VCR you want under the VCR but, Cable codes under the CBL, etc
Note: if the device does not have a chat channel at a button, you should Play (VCR only) or Power instead.
Here is a Code List on PDF that shoud be universal for most remotes. It worked for me.
http://www.remotecodelist.com/remot...ps-Magnavox_PM525S.pdf
Hope this helps you out, good luck.
3helpful
7answers
Simplicity 4 in 1 Crib combo
i have lost the directions to my 4 in 1 simplicity crib, we are trying to convert it to a twin or the daybed but do know how, the manafacturing code is 3804cw and the vender item # 8994w, if u have any info on this bed please let me know.
Lost Instruction sheet for cl034
Change clock time on car stereo,
the connections at the back of your player seems to be color coded... try to trace them and try to connect if there is of course red wire directly to the battery and the orange one to the "acc" or the accesories line
Weiser Lock GED1460X3BR Lifetime Polished Brass PowerBolt Powerbolt Touchpa Logo
Top Weiser Lock Locks & Locksmithing Experts
john h
ray gallant
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
