Repair manuals aren't available for free download. Owner/operator's manual are though. Most service centers won't even repair electric trimmers, saying that the work is not cost effective.
Here is a link to the closest thing to a repair manual.
http://216.213.143.2/ProAuthor/ManProc.cfm?&sk=29830CA7%2DF9A0%2D11DF%2D9262%2D00D0B789305D&&ProcID=9812&ManualID=300&ProductID=-1&Edit=No&Skill=1&Lang=-1
SOURCE: TORO 51464 Electric trimmer battery: can it be
Yes you can replace the original battery. It is recommended you have it done by and Authorized Service Dealer.
When the battery no longer holds a charge, you can purchase a new battery and have it installed at your
Authorized Service Dealer. If you want to discard the trimmer, remove and recycle the battery before
discarding the trimmer.
1. Remove the 2 bolts and nuts securing the trimmer handle section to the black center section.
2. Remove the 6 screws securing the two halves of the handle section together and pull the halves apart.
3. Remove the battery and disconnect it from the wire leads.
4. Discard the trimmer.
5. Recycle the lead-acid battery according to local codes.
Find you nearest dealer here:
https://homeownersolutions.toro.com/portal/server.pt?space=CommunityPage&cached=true&parentname=CommunityPage&parentid=2&in_hi_userid=30166&control=SetCommunity&CommunityID=226&PageID=30037
The part number for your battery is: 106-1905
