HP PSC 1350 All-In-One Thermal Printer Logo
Posted on Dec 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i print envelopes on the HP 1350? - HP PSC 1350 All-In-One Thermal Printer
Rick Hurd
Level 3:
  • Master 285 Answers
  • Posted on Dec 01, 2010
Rick Hurd
Master
Level 3:
Answers
285
Questions
0
Helped
126175
Points
1051
  • Remove all paper from the paper tray.
  • Slide an envelope into the tray, with the envelope flap up and to the left (print side down), until it stops.
  • Adjust the paper-width guide against the envelope.
  • Be careful not to bend the envelope.
  1. In Microsoft Word, click Tools , click Letters and Mailings , and then click Envelopes and Labels .
  2. In the Envelopes and Labels dialog box, click the Envelopes tab.
  3. Click Options .
  4. From the Envelope size drop-down list, select the required paper size. If you created a custom paper size, select the new custom paper size from the drop-down list.
  5. Click OK , and then click Close to close the Envelopes and Labels dialog box.
  6. Click File , and then click Print to print the envelope.
My Riso Duplicator puts a score on window envelope while printing. How to solve the problem?
Don't print window envelopes or try a different make that are made better. They are often problematical. Video from the maker at the bottom.
Printing Envelopes on a RISO Inkjet Printer
Riso UK https://www.riso.co.uk > pdf > Printing-on-Env... PDF We have conducted a series of evaluation tests to determine which envelope types can be recommended for use and the results are shown in the charts shown ...
2 pages
Solved: Melting plastic on envelopes
HP Support Community https://h30434.www3.hp.com > LaserJet-Printing > td-p
When printing envelopes with my M605 HP Printer, it melts the plastic view windows. Any suggestions?
Thread: #10 window envelopes - Konica Minolta
Copytechnet https://www.copytechnet.com > ... > Konica Minolta
Aug 11, 2012 - We have a Minolta 452 and 552. Looking to print #10 window envelopes. I bought heat resistant window envelopes. Put them thru the machine ...
2answers
Printing envelopes it prints crooked
HP OfficeJet Pro K8600 Printer
Printing envelopes
Photosmart D7460 will not print envelopes from Printshop 23
u should go to print setup in ur program then go to paper type which u want to use it then select "Envelop" instead of "A4"
2helpful
My HP 1350 will not print cards/envelopes from the right side of the printer. They have to be loaded on the right but the printer keeps printing in the center.
Printing envelopes with an HP 1350:
If you use MS Word, select ENVELOPES. When address window appears, select OPTIONS on right > select PRINTING OPTIONS > select FEED METHOD option on far right (envelope placed on right of tray face down); select FACE DOWN; select FEED FROM UPPER TRAY. The only problem I have with this is that the address prints off in the lower quarter of the envelope rather than in the center of the envelope as we would write it manually. I am currently working on solving that problem.
My HP LaserJet 4200 prints fine from tray 2, but will NOT print envelopes from tray 1. It WILL print on regular paper from tray 1, but will not print envelopes. What gives? I've already rebooted the
Are there settings on the control panel of your printer?
Is the tray 1 the MP tray? (The one that flips towards you)
If so, can you change the settings of the Tray 1 to Envelope on the control panel?
I hope this helps.
Hp 1350 printer-scanner shut self off and won't turn on.
In pulling out the envelope, I guess I pulled the machine just enough to loosen the power plug at the back of the printer/scanner. It appeared to be plugged in, but wasn't, just enough to not make contact. Thus it baffled me why it wouldn't turn on, nor show any signs of life.--
2answers
HHow do I print envelopes on a deskjet940c. What is the set up.
Here is a how-to for the printer, but I'm not sure if you mean the printer, or in a program.
If this is not what you need, let me know.
HP Deskjet 920c and 940c Series Printers - Printing Envelopes s.gif s.gif s.gif
gtabblt.gif Loading a single envelope gtabblt.gif Loading multiple envelopes gtabseps.gif Loading a single envelope Preparing to print
  1. Place the envelope, with the flap side on the left and facing up, into the single envelope slot.
  2. Push the envelope forward until it stops. See Figure 1.
Figure 1: Inserting the envelope c00104463.jpg Printing guidelines
  • Verify that the Out tray is in the down position.
  • Avoid using envelopes that have clasps or windows.
  • Avoid using envelopes that are shiny or embossed, envelopes with thick, irregular, or curled edges, or envelopes that are wrinkled, torn, or otherwise damaged.
Loading multiple envelopes Preparing to print
  1. Pull out the In tray.
  2. Slide out both paper guides and remove all paper from the tray.
  3. Place no more than 15 envelopes -- with the flap side on the left and facing up -- in the tray.
  4. Push the envelopes forward until they stop.
  5. Slide the paper guides snugly against the edges of the envelopes, then push the tray forward until it stops. See Figure 2.
Figure 2: Inserting multiple envelopes c00104464.jpg Printing the envelopes Each software program is different and requires different steps to successfully print envelopes. For instance, in many versions of MS Word, clicking Tools , and then Envelopes and Labels , accesses the envelope-printing feature. Other software programs will differ from this procedure. Consult the Help menu on a software program or User's Guide for instructions for the particular application. Printing guidelines
  • Never place more than 15 envelopes in the In tray at one time.
  • Align the envelope edges before inserting them.
2answers
Hp psc 2410 photosmart
marglet, Turn-off and unplug the printer for a couple of minutes...there may be improper setting stuck in the printer memory. then plug it in and try to print the envelopes..if that doesn't work...Make sure there aren't any custom print settings causing this. Lastly...Try updating the drivers. Download the latest drivers from the site. http://www.shopping.hp.com/webapp/shopping/search/search_request.do?pageName=HP+printers_land Good Luck, Tim
k24674
Grand Canyon Tech
Grand Canyon Tech
