Reddy Heater-170,000 BTU Kerosene Deluxe Logo
Posted on Dec 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fan motor won't stay running - Reddy Heater-170,000 BTU Kerosene Deluxe
T bone 1963
Level 2:
New Friend:
  • Expert 70 Answers
  • Posted on Dec 01, 2010
T bone 1963
Expert
Level 2:
New Friend:
Answers
70
Questions
0
Helped
30951
Points
199
If it runs for awhile and then smokes and then shuts off, the problem is usually in the fuel system. If you have never serviced your unit, it may be time to do it. Most fuel tanks start sweating during the hotter times of the year. This moisture builds up and settles on the bottom of your tank. Your suction fuel line is real close to the bottom and the water in the fuel ends up spraying on the ignition plug or glow plug causing it to put out the flame and the units circuit board shuts down the unit because of a flame was not sensed. Check the fuel if it is not fresh, change it. Usually there is a drain in the bottom of the tank. Good luck.
2005 Yukon coolest fan won’t shut off
If the cooling fan stays running, it's possible that your cooling fan relay is stuck in the on position and is supplying constant power which is why it stays running. Swap the relay with a similar one in the fuse box to see if it goes off. If it does, replace the relay. If it doesn't, you may have a wiring issue or possibly a computer issue which is grounding the relay for constant per..
1helpful
Ac fan not running, but compressor runs on and off
switch/ fuse possible if it has one, if not one of the wire going to the motor was severed, or the start up capacitor of the motor if it also has one.
2helpful
Heil furnace blower motor stays on won't shut off at thermostat blows cold air continuously
Do you have t sat fan switch in on position??? If so blower will run continously set it to auto and it will cycle with heat call
Fan won't stay running and temperature sensor flashes
Sounds like the fan needs replacement. A faulty fan will shut the set down and the tem light will falsh in most cases.
We have a kenmore ultra wave microwave and the fan has stopped working and now the microwave won't operate. Any suggestions?
see this causes and fix it .God bless you
Exhaust Fan Motor If the exhaust fan does not run the fan motor might be bad. Remove the fan motor from the microwave oven and see if the blades can be turned by hand. They should turn very freely, if they're stiff the fan motor will need to be replaced. The fan motor can also burn out. To test this use an Ohm meter. The motor should have continuity. If it does
Thermostat If the microwave exhaust fan is not working the thermostat might be defective. The thermostat senses the air temperature and turns on the fan as needed, if it's defective it won't turn on the fan. Watch our video on testing thermostats.
Main Control Board If the microwave exhaust fan is not working check the exhaust fan motor and wiring. If they are good the main control board might be defective.
1helpful
Condensor Fan won't stay running
Check capacitor if its good its the motor
Is it the engine cooling fan or some type of fan relay switch because my fan stopped working and jeep overheats when idling or at speeds below 30mph while A/C is on.
I would look to the electrical side of the fan operation. You have three basic components to the cooling fan operation...the fan switch, the fan relay, and the fan motor. You need to determine what part of the system is not working. If you can run a 12V jumper wire to the motor and it works you know it must be either the switch or the relay. if you jump out the switch and the fan runs, you know it must be the switch.
Fan won,t run on 2000 Ford Contour
fan motor may be bad. also could be a sensor. you can jump the fan motor off of the battery to see if it works.
9helpful
2answers
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Paul Carew
vince
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
