Universal Remote Control Codes For TV & Audio. ... Codes for Philips Universal Remotes · Sanyo TV Codes for Universal Remotes · Codes for .... I have an 19 inch Emerson flat screen and a RCA universal remote. Please help with the code ..
U have ur tv original remote look for a button like ViewMode,Aspect Ratio,Picture sizes,Picture Zoom.Tries pushes one of these buttons a couple times,u should able to changes ur tv pictures sizes.
Tries used the manual buttons on the right or left sides of the tv?Look for buttons that said INPUT or FUNCTION buttons.Push one of these button that said INPUT or FUNCTION pushes to the input VGA mode u want.Or try website Remotes.com to buy an original tv remote.
You have two possibilities; either buy the original remote or look up the code for 'universal' remote for that set here:
Remotes
If you can't find the code set for the remote & TV you have, look for a code set for one of the following brand names:
Funai, Symphonic, Sylvania, Emerson, Aventura, Durabrand,
ESA, Magnavox, INSIGNIA, Philipsand Misakai
Me thinks IF you tried the 'code search' function and none worked, I sincerely doubt if anyother 'codes' will marry your Philips Remote to your electrohome TV.
This is because your "SEARCH" effort already went through ALL of the possible codes THAT Philips Remote knows andcan deliver. It is also possible that a different MODEL of Philips Remote MAY stumble on codes that DO work!
IF you have a 'original' remote, SOME NEWER remotes can LEARN the proper codes from the original remote! BUT you NEED that original remote to send the desired IR data pulses to the smart student remote.
And GOD ~ those TV's are SO OLD, did they even HAVE remotes??
check out Philips support website for codes and instructions for that individual remote. most of their codes are the same for most of their universal remote controls. I suggest getting the original replacement remote for your TV because then you can easily just put batteries in the remote and not have to worry about programming and loosing codes. get the original at www.replacementremotes.com and at the top of the site just type in your model number of you TV and click search. They will set you up with your original remote.
Don't know if you have the original codes or not, but here are the codes for Phillips TV's from the original manual. Hope this helps. Try them one at a time and see if they work.
