Inside the door under the filter housing is 2 strips that sense wetness. If they have dryer sheet goop on them they won't sense moisture. the dryer will therefore thank them clothes is dry. Clean them sensors with windex and party on!
One thing you can do is clean the sensor strips located inside the dryer.
Get some windex and clean the coating off them. Dryer sheets rub against the strips and form a barrier. The machine THINKS the clothes must be dry because it ain't SENSING dampness from wet cloths rubbing against them sensors.
Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Dirty moisture sensing strips? Have you tried cleaning them with windex?
Number 34 these measure resistance by picking up wetness from the clothes. Dryer sheets can coat these with a non penatrable film which fools the brain into thinking them clothes is dry so it moves towards the cooldown mode and shuts off with wet clothes. Clean them sensor strips real good and party on!
Easy fix: Look inside the drum below where the filter goes in. You will see two metal strips. They sense the wetness. Now get this: the dryer sheets rub against them and a thin wax buildup on them prevents the controls from properly determining wetness. The control has no clue the clothes are still damp and thinks everything is kosher; so it advances to the end. Solution. Clean the stuff off of the sensors so that they can sense the true wetness once again.
Check the heat sensor in the auto setting it is usely on the drum that's what turns the dryer off when it is dry . The wet clothes get against it when they are dry it shuts off. Hope this helps
