Lightning Audio Strike S2.600.2 Car Audio Amplifier Logo
Question about Lightning Audio Strike S2.600.2 Car Audio Amplifier
Where can I find the power plug for this amp?
Posted by richsimmons1 on
Greg Douglas
    New Friend:
    Problem Solver:
  • 11 Answers
Yes this amp requires a power plug connector which almost resembles a 3 prong AC plug. Very odd, and can't find one anywhere.
Posted on Jun 04, 2016
kenw392
    An expert that gotĀ 10 achievements.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Lightning Audio Master
  • 2,226 Answers
Are you sure there is a power plug needed for the amp? very few amps require power plugs. you merely have to run wires to the power terminal. the power terminal should be labeled - pwr (b+), grnd, and rem.
Posted on Dec 01, 2010
I have a yjs052402500d and I am missing the power cord that plugs into the switching power supply, the cord that plugs into them wall
I believe that is standard plug for desktop computers. Any computer store or office suply store should havery it.
https://www.walmart.com/ip/3-Prong-Pin-AC-Power-Cord-Cable-for-PC-Desktop-Computer/49360006?wmlspartner=wlpa&selectedSellerId=1229&adid=22222222228036914916&wl0=&wl1=g&wl2=m&wl3=83293216354&wl4=pla-186604474354&wl5=9004519&wl6=&wl7=&wl8=&wl9=pla&wl10=112549857&wl11=online&wl12=49360006&wl13=&veh=sem
96, ford mustang, after market radio installation help! where to plug the amp remote wire for amp
The blue wire is a triggering wire of a low amp power for Amps or a power antenna. If it draws too much power (gets hot), use a relay for more power directly off the battery.
e,g..2 amp radio output and if the amps need 1.5 amp each that's 3 amp. Need a a relay.
Connect to power amp
plug the bars out plug whatever to the pre in, then the remote out to the power amp.
1998 komfort 5th wheel electical problem
i am not certin that i have ever encountered a situation that has 2 outside power input plugs, the situation is that your trailer is wired for a 50 amp service, this service has a plug that has 4 connection points and is set up for a 220 volt supply, the only reason for this situation is that some one modified the power input to your trailer , the solution is to eliminate one of the 30 amp power supply connections and in the fuse panel bridge the 2 hot side supply rails, or better yet restore the power connection to the 50 amp service cable and purchase a 50 amp to 30 amp power adapter cable
1helpful
Wish to run sm450v2 Mackie powered speakers thru a Peavey XR8600
The Peavey XR8600 is NOT just an amp, but a powered mixer.
To SAFELY use this with your powered speakers, connect those speakers to the MAIN and MONITOR outputs on the front of the unit with 1/4 inch INSTRUMENT rated cables (NOT speaker cables).
To safely leave the power amps in the XR8600 with no output loads, plug GROUNDING plugs into the POWER AMP 1 and 2 input jacks on the front. This will prevent the power amps in the XR8600 from running with no load which COULD damage them.
Make the grounding plugs from 1/4 inch mono plugs by jumpering the centr aand sleeve terminals of the plug.
No power whirpool washer AWOD 5506
Hiya,
i can only surgest a simple check for you with this one & that would start with the plug, open the plug & check all the wires are were they should be if so try a fuse change & hopefully this will solve your problem if not try plugging it into a differnt socket just to be sure theres not a power issue between the socket & plug.
Hope this helps
The power does not come on
Would request you to try some of undermentioned steps, this would help you identify what is the main issue:
  1. Try different power source or outlet. Make sure that the power socket is working properly.
  2. Unplug all cables from back of modem & plug only power cable. If power light does not come on, then you might need to get modem or power adapter changed.
  3. If power light comes on, then plug sat in & out cable, if light goes off then issue could be with these cables & you might need to call your ISP provider to send installer & look after the dish.
  4. If power light is still on, then plug lan cable & if light goes off then you need to change LAN Cable.
I don't know where to connect the main in & pre amp jacks??? to the EQ???
Not sure I understand your question, but I will try.
Your CD players, tape decks, etc., connect to the INPUTS on the preamp.
The LINE OUT on the PRE AMP connects to the LINE IN on the POWER AMP.
The pre-amp does some amplification and then it passes the signal along to the power amp, which will do the heavy lifting - driving the speakers.
The connection is usually through a shielded RCA plug cable. THere will be 2 cables from the Pre amp to the power amp - one for the left channel and one for the right channel.
The OUTPUT Of the power amp will connect to the speakers using large, stranded wire cables, sometimes with "banana" plugs that simply plug into the terminals on the power amp and the speaker.
Let me know if this gets your started.
Describe your Black &
I have a black and decker 100 watt power inverter. When the led turns red you are ethier overloading it or it overheated. to fix it unplug it and let it sit for 5 minutes. Plug it in. Plug in an item rated for 100 watts or less. Or try to charge somthing on the usb port.
4answers
Loud buzzing when amp connects to guitar
Is there a loose connection anywhere?
Jan 03, 2009 • Music
Top Lightning Audio Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Lightning Audio Car Audio and Video Expert? Answer questions, earn points and help others
