Question about Toshiba Satellite® A215-S4807 PC Notebook
My Toshiba Satellite Pro L510 freeze at bios logo and can't press the hotkey. I'm only installing Windows 7 Ultimate, and i don't do anything except that. Any solutions ?
Posted by ai_dreamz on
5 Related Answers
Anonymous
  • 624 Answers
SOURCE: HOW TO ENABLE TOUCHPAD ON TOSHIBA SATELLITE PRO M15-S405
Press the Fn and F9 keys, that should turn it back on. Let us know if that solve your issue and please dont' forget to rate this posting.
Posted on Feb 09, 2007
Anonymous
  • 67 Answers
SOURCE: BIOS is not appearing in Toshiba tecra laptop M1
You can enter BIOS by holding down F2 after power on. Hope this helps.
Posted on Oct 20, 2008
KovaZg
  • 19 Answers
SOURCE: hotkey driver problem with windows 7
If nothing doesnt work.
Flash bios, then install Common module from Toshiba download page, then install Hot Key Utility, then TVP (Toshiba Value Pack), or just Value Pack on toshiba download page, and voila, it should work !
I have A300 - 1LT, but I think its on all A300 same. I found TVP for 64bit Vista (I use them on my Win7 64bit), if you can't find what I mentioned above, then don't put your model nubmer, just pick A300, and don't mark OS, and download what I mention.
Cheers.
Posted on Oct 30, 2009
peepnklown
Frank
  • 175 Answers
SOURCE: unlock bios Toshiba Satellite Pro A60FR !
This WEBSITE should help you out:
http://www.tech-faq.com/reset-bios-password.shtml
Posted on Dec 08, 2009
Anonymous
  • 349 Answers
SOURCE: WEBCAM DRIVER OPEN FAIL. Toshiba M300 satellite
Go here and download the driver utility for your webcam.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2228766&rpn=PSMD8U&modelFilter=M300-ST3402&selCategory=3&selFamily=1073768663
Posted on May 02, 2010
Bios password toshiba satelite l300
Method 1 (Flash BIOS)
Flash BIOS for Satellite L300-ST2501
Flash BIOS for Satellite L300-ST3502
1. Remove the battery and don't turn on the laptop (a minimum of one day or more). To remove electric current, which is still stored in the laptop. Based on experience, can turn a normal laptop, try to enter windows.
2. Download Flash BIOS slb0v150.exe then open the file, select Install, and select Install from Windows - OK.
Flash BIOS can remove the BIOS password
Method 2 (Manual)
source image : bios-repair
With solder, remove the BIOS IC, wait about 10 seconds, then plug it back. To remove the BIOS IC, you must remove the screws down and the LCD.
I hope this information helpful.
Oct 20, 2011 | Toshiba Satellite Pro L300 Notebook
How to format my laptop l510 with window 7
If you want to upgrade, simply insert the CD and follow the autoplay options. If you want to fully erase your computer and then install Windows 7 (warning all personal data will be gone). Then you need to enter your BIOS, set the first boot method to CD, and restart the computer WITH the windows 7 CD in the drive. It should prompt you to boot from the CD by pushing any key, go ahead and do that then follow the on screen instructions. When it asks you what partition you want to install it on, delete your existing partitions, then recreate partitions as you want them.
Apr 10, 2011 | Toshiba Satellite L510 Laptop AC Power...
After I installed Windows 7 ultimate on my pc, I found that when I press the FN key, the icons showing the various functions at the top of the screen no longer show.
You need the hotkey driver utility.
Find your model on Toshiba's support page here. Then look for the above, if there is no version for Windows 7, one for Vista should work.
Mar 18, 2011 | Toshiba Satellite L515S4960 Notebook
Install drivver web cam toshiba satellite L510 in my laptop
Enter "csd.toshiba.com" in your address bar.
Select "Download"
Select "Laptops" then "Satellite" then "L510" and click "Go"
On your keyboard press "Ctrl" and "F" and type the word "refine"
To the right of that there will be two drop down menus. Using the menu to the far right click the down arrow and scroll down to select the "camera" option.
Click the "Web Camera Application" link
When prompted for "Save as" select the 'desktop'
When the file is completed, double-click it and conclude setup.
Mar 06, 2011 | Computers & Internet
Toshiba satellite pro L510 web cam driver
why my toshiba satellite l510 web camera can`t use ?
Aug 05, 2010 | Computers & Internet
How to install windows 7 on Satellite A205-S5880
To install Windows 7 no need for RAID driver. If you face issues in installing Windows 7 disable RAID in BIOS, install Windows 7 and then install RAID driver.
How To Manually Upgrade from Vista to Windows 7 - Satellite A200/205:
http://cdgenp01.csd.toshiba.com/content/support/downloads/PSAF3U-PSAF6U-Win7UpgradeInstructions.pdf
Windows 7 Drivers page:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2060003&rpn=PSAE3U&modelFilter=A205-S5880&selCategory=3&selFamily=1073768663
Dec 31, 2009 | Toshiba Satellite A205-S5880 Notebook
No display/monitor problem? When I turn on my Toshiba Satellite pro L300, I can see the Toshiba logo, bios menu, windows loading logo etc, then when it loads my desktop, nothing! No display, no graphics...
When you press power button press F8 key then enter in enable vga mode.
Then go to display proeprty and set screen rsolution to 1024*768 then apply.
Then check.
Aug 20, 2009 | Toshiba Satellite Pro L300 Notebook
Hotkey driver problem with windows 7
  1. Download the XP version of the hotkey driver here: http://support1.toshiba-tro.de/tedd-files2/0/thku-20080805075706.zip
  2. Extract it, and right-click on the installation file and choose Properties
  3. Go to the Compatibility tab, and make it Windows XP
  4. Press OK and try installing it again
If that doesn't work:
  1. Right-click the driver's installation file and choose Troubleshoot Compatibility, and follow the on-screen steps
Hope this helps!
nLinked
Computer Support Services
Jun 06, 2009 | Toshiba Satellite 1115-S103 Notebook
Toshiba Satellite® A215-S4807 PC Notebook Logo
376 people viewed this question
Top Toshiba Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
