Sanyo SC-H2000 Bagless Upright Vacuum Logo
Posted on Dec 01, 2010
Can't find a belt for my sanyo sc-h2000 locally--is there a hoover, or bissell or eureka belt that will work for the sanyo?
triumf gjoncaj
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 04, 2014
triumf gjoncaj
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
146
Points
Cant find any belt for my Sanyo SC-H2000,there is any other brand belts that will work with Sanyo
I am trying to replace my vacuum belt and can not get the roller brush to fit back into the slot after I put the belt back onto one end of the roller brush. Am I reassembling the belt and roller brush the...
if its a hoover or bissell, one side of the brushroll is slotted and slides. if its a eureka the hexagon end caps must be properly aligned, they go in at an angle. if its none of these provide me with the make and model # and i will give you a detailed description on installation. let me know if you need more help.
Jan 04, 2010 • Vacuums
6helpful
2answers
Eureka model 4335 - belt removal (top cover)
Hi.  There are 16 different models of Eureka 4335, and frankly I don't know how much difference there is between them.  You can download a copy of the user manual from the website below.
If that doesn't work for you, please re-post - stating exactly which model you've got, and I'll guide you through it.
Good luck. If this has helped, please remember to rate me!
http://www.eureka.com/servlet/FindOwnersGuide
2answers
Which is the best caprpet steam cleaner mid priced?
I would recommend the Hoover brand. The Bissell's are very problematic, they have belts that break and issues with the heating elements. Hoover Steam Cleaners can be repaired and are simple to use. The price range is generally $180 - $300
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
I am trying to replace the style 7 belt on the 32074 bissell and need help doing so....its the one that the brush ride on!!!!
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=749442
Generic problem for all Vacuums
Posted by pimpjnya on Jul 06, 2008
I am trying to replace the style 7 belt on the 32074 Bissell and need help doing so....its the one that the brush ride on!!!!
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. In order to get @ the belt on the Bissell, there should be screws, levers, or clips to remove the bottom plate and either the bottom plate will come off of the top cover will come off depending on if it is an older or newer model #. Also you can refer to the Bissell owner’s manual trouble shooting manual for tips on changing the belt as well. If not you can get an owner’s manual from the Bissell factory website or phone # listed below. If you have further questions please feel free to contact your local vacuum cleaner dealer in your area, or contact the Hoover website and or the cust serv phone # @ Hoover listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ Customer Service 1-800-237-7691
Hours of Operation Monday thru Friday 8:00 am to 10:00 pm EST
Saturday 9:00 am to 8:00 pm EST Mail To: Headquarters, Bissell Homecare Inc
P.O. Box 3606 Grand Rapids. MI 49501
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 06, 2008 • Vacuums
Possible broken belt..brush doesn't turn on Sanyo Revo SC TA3000 vacuum. Cannot find manual.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=748077
Possible broken belt. Brush doesn't turn
Posted by Helene on Jul 06, 2008
Possible broken belt. Brush doesn't turn on Sanyo Revo SC TA3000 vacuum. Cannot find manual.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. You can contact the Sanyo factory phone # and or your local vacuum cleaner dealer for the belts. But the owner’s manual you would have to contact the Sanyo factory @ the phone number provided below. If you have further questions please feel free to contact your local vacuum cleaner dealer in your area, or contact the Hoover website and or the cust serv phone # @ Hoover listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://us.sanyo.com/appliances/vacuum_cleaners/
Customer Service – Go to the Contact Us page and fill out the email request
The Service Center Cust Serv Line 1-800-421-5013
Monday thru Friday 7:30 AM to 5:00 PM (PST)
Go Ahead. Use Us.
1helpful
Eureka Altima is smoking!
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618889&thid=606496
Posted by saysay on May 18, 2008
Help! My vacuum is smoking. It won’t work anymore and starts to smoke as soon as it gets turned on.
Eureka Altima Upright Vacuum Model #2996AVS – it is probably doing 2 things, it could be the belt and or brushroll and the easiest ay to check is to remove the belt and see if the motor smokes, if the motor is fine then buy a new belt and check the brushroll to see if the brushroll spins freely, there are bearings in the brushroll and thread and hair get bound up in the ends and needs to be cleaned out. So #1, check the belt – no smoke from the motor then check the brushroll to see if it spins freely then changed the belt. If the motor smokes check your purchase date it may still be under the one year factory warranty from the dop. #2. Either clean or replace the brushroll and belt. If you have any further questions, feel free to contact your local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don The Vac Man
Go Ahead. Use Us.
I would like to know the name and address of Bissell Dealer in the Salisbury MD area? I need to buy cleaning products. Ben J. Ames
You can buy Bissell products @ your local vacuum cleaner dealer in your area in the yellow pages, or you can check the Bissell factory service number listed below or the Bissell website. Sometimes you can use other products (low sudsing) from other machines such as the Rug Doctor, Thermax, Hoover, Eureka etc.,
http://www.bissell.com/ By Phone Customer Service:
(800) 237-7691 Hours:
M-F 8:00 a.m. - 10:00 p.m. ET
Saturday 9:00 a.m. - 8:00 p.m. ET
Don - The Vac Man
Apr 22, 2008 • Vacuums
Top Sanyo Vacuums Experts
john h
Are you a Sanyo Vacuum Expert? Answer questions, earn points and help others
