Question about HP LaserJet P1505n Printer
I have of got problem with HP laserjet P1505n printer, which is when someone did not print for a about 10 minutes, and then try to print something, always it doesnt print until user manually push the power button of the printer. next is if someone send a print job to the printer when there are no paper on the tray, the status of the printer says "out of paper" on the PC and even after adding papers to the tray, neither Printer nor PC will detect it. the print Job will hang and nobody else in the network also will not be able to print. the only way of bring the device working is restart the print spooler service in the PC and delete the print job. I am fed-up with this issue and hope some would help me to come out of this pain. thanks in advance.
Posted by samantha_lk on
Brandan Heasley
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 49 Answers
You should be able to reset the printer
Posted on May 31, 2019
5 Related Answers
MUKHTAR
mukhtar21 shaikh
  • 2022 Answers
SOURCE: printer won't print
switch of the printer first remove the usb cable from the printer and uninstall the printer driver nad remove printer from device manager also. to go to the device manager do these steps first right click on my computer and then go to properties and the click on hardware tab and then click on device manager and go to universal serial bus controllers just click on + tab it will expand and it will show the list of connected hardware select usb printing support and right click on and uninstall then restart you system. after coplete boot run the driver software and connect the usb cable when it will prompt you and switch on the printer. it will install your printer
Posted on Sep 22, 2007
Nikhil Gedam
Nikhil Gedam
  • 87 Answers
SOURCE: hp laserjet 4250
This happens when the printer is printing duplex job. i.e. trying to print the other side of the page.
However check the functionality of the printer by performing Paper path test.
This would help us to know whether the printer as a stand alone ... is fine or not.
From the control panel of the printer, scroll to Diagnostic > paper path test.
Select the following in sequence.
Source: All trays
Copies: 10
Duplex: ON
Print Test Page
Check if you get the same error.
If yes, upgrade teh firmware of the printer.
Let me know the end result. We still have more depending on the above test.
- Nikhil
Posted on Nov 04, 2008
leroyal
Leroy Elliott
  • 2120 Answers
SOURCE: HP Laserjet 4050 hangs on processing job
Unplug printer cable.
turn off
turn back on and wait for READY
turn off
connect printer cable
turn on
Posted on Jan 05, 2009
Anonymous
SOURCE: Cannot print on shared printer
I had the same problem with HP 1018 printer, when I had two computers connected to a domain and had Windows XP SP3 on them and when I shared the printer on one of them - I could only print from the network if the user belonged to the Local Administrators group on the host/server computer. Once the network user is removed from Administrators - the print jobs are stuck in print queue. I used the "HP LaserJet Host Based Print Driver Package" that is on HP web site for HP laserjet 1018 printer.
Then I tried to use a different driver for that printer and was successful with driver for HP LaserJet 1020. After forcing that printer to use the 1020 drivers, the regular users were able to print to that printer.
Posted on Jan 28, 2009
Anonymous
  • 8 Answers
SOURCE: hp 2420 prints a ''job storage status page'' after each print job
If you have your software driver or print job set to save your print jobs to the printer and your printer does not support this, you will get that error and status page. Here is what the User's manual says about print job storage:
"The printer supports two distinct job-storage features that you can use to initiate printing from the printer control panel after the print job is sent from the computer:
● Proof and hold jobs
● Private jobs
Make sure that you identify your jobs in the printer driver before printing. Using default names might override previous jobs that have the same default name or cause the job to be deleted.
The job-storage features require 48 MB of RAM. For printer models that have less than 48 MB of RAM, you can add memory so that they can support the features."
Posted on Apr 16, 2009
Printer will not print queque HP Laser Jet P1505
first remove the power and usb pin from the printer wait for few minutes then connect them back into the socket then click printer icon in the task bar and open it and remove all the contents then again remove the power and the usb of the printer and restart your computer then connect the power plug and the usb into the printer then click start settings printer and make your printer default then right click your default printer and select properties in the printer properties click print a test page
Apr 01, 2011 | HP LaserJet P1505n Printer
I am using Windows 7 but I cannot install my printer as I need to have drivers first
HP LaserJet P1505n is compatible with Windows 7and you can download the drivers from HP Official Support.
Visit the above link. Select the Operating System (Windows 7) (32-bit OR 64-bit) and download the drivers fro FREE
CreativeTECH
Jan 24, 2011 | HP LaserJet P1505n Printer
My printer is reporting the door open. i have tried all i can to resolve it. kindly help
remove the toner/cartridge and then unplug the power from the printer.. after about 10 seconds, replug the printer and insert the toner .. Now, ensure that the door is properly closed ..
Sep 03, 2010 | HP LaserJet P1505n Printer
One default vertical line is printing in the right side of the printable area on the printed paper
i have hp printer laser 1505, it can print out and i set the paper on portrait. but the output of printing out is the characters are on landscape style. So what should i do...plz help me if somebody can solve it
Will not print periodically. Cannot clear print
Try downloading the latest driver from HP: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=3435671&lang=en&
Often times the drivers on the CD are already out of date.
Hope this helps! If so, please give a rating!
Mar 09, 2010 | HP LaserJet P1505n Printer
Self test is not comming
make sure the toner is not empty. try with other toner and then go for print.
Feb 02, 2010 | HP LaserJet P1505n Printer
HP P1505 LaserJet won't print Acrobat files
I would update to the latest adobe acrobat reader and see if that works.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_7148ad2a373711a3
Jul 30, 2009 | HP LaserJet P1505n Printer
HP LaserJet P1505n Printer Logo
190 people viewed this question
Ekse
efs_perpends
efs_perpends
