Question about Polaroid PhotoMax PDC 3070 Digital Camera
I am trying to get my camera PDC3070 to work on my new computer but my cd will not install so I need a download or driver
Posted by etgrannew on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Polaroid Master
  • 102,366 Answers
Consider NOT using a driver.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Posted on Apr 20, 2011
My computer can't read camera and headphone
Hellooooo friend..............
Check first if the battery of your camera has the enough power to operate while it is plugged to your laptop.
If yes and still does'nt work.
If that's brand new, you'll find two kind of CD in the packaging; one is the installation CD and the manual CD. Install the installation CD for it will load the Driver of your camera. Then try to upload you picture again.
If that's not brand new, connect to internet and download the camera driver while your camera is plugged to your laptop
Sep 21, 2011 | Computers & Internet
Need to intall my pc camera
Normally if you just connect the pc camera to your computer , it should start to install the needed drivers automatically ... try that to see if it works (if you cant find it , it will be in my computer) if not : if it doesnt , insert a cd that you recieved with it and install programs from it
if cd is not included : go online and search you make and model drivers and download then install the needed driver (drivers are like softwares tht is needed to run your camera )
Jun 20, 2011 | Cameras
I lost installation CD need a new CD
You can download the software from the sony website. Try searching google with the make and model of your camera + "computer driver" for whatever type of computer you have.
May 31, 2010 | Sony Handycam DCR-SR100 Camcorder
Can't download pictures from my camera to computer with windows xp. Manual says that a new removable disc icon should appear in my computer but it doesn't.
In order to download or view pictures stored in your camera to your PC, you have to install the drivers. Follow these steps
1- Use CD which came with your camera, and install the drivers for your camera. If you do not have the CD, You need to go to the pentex and download the drivers for your camera and operating system.
2- After installing the drivers, connect your camera, follow the screen to install the drivers. When it says ready, the icon will show up when you click start, then computer .
Now you can download, copy or view the pictures stored in your camera.
GOOD LUCK !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 16, 2009 | Pentax Optio 60 Digital Camera
I can't download pictures to my computer
How do I transfer pictures on my digital camera to my computer?
AFTER INSTALLING THE SOFTWARE FIRST, WITHOUT THE CAMERA BEING CONNECTED TO THE COMPUTER, DOTHE FOLLOWING: 1. Turn on the Camera, and change it o "Playback" mode. 2. Connect the camera with computer using USB port. 3. The LCD display of the camera turns off automatically, and the computer said " that a new hardware attached would be detected". 4. Go to "My Computer", and you can find a new drive saying "Removable disk". Double click it and you can find your pictures and videos inside the folder. Just copy them to your computer's hard disk. This procedure is slightly different for each digital camera model. You will need to refer to your instruction manual (Included on the CD-Rom that came with your camera) for exact instructions on how to properly install your camera and download your pictures. The main thing is to first install all of the software on the included CD-Rom disc to your computer BEFORE CONNECTING THE DIGITAL CAMERA TO THE COMPUTER. If you do not do this, Windows will put in its own driver and it is virtually impossible on some computers to get this driver out of Windows and install the proper one. However, if you do find yourself in this position. You can TRY the following. First unhook the camera from the computer, go to: Start / Control Panel / Add/Remove Programs. Next, look for all of the DIGITAL CAMERA software listed under the "Installed Software List" and uninstall that software. This is the same software you HAD installed after hooking up the camera to the computer. Once you have uninstalled ALL OF THE CAMERA software, reboot the computer, then re-install the software WITHOUT the camera connected to the computer. If this works, great! if not it is because Windows refuses to accept the new digital camera driver or Mass Media Driver needed and short of reinstalling the Windows software there is very little you can to do to make it work other than by purchasing a different model digital camera and installing the software FIRST before attaching the camera to the computer. If you think this is just a Cobra Digital problem, do a search on the internet. It occurs with almost all brands of digital cameras on the market, usually the ones that use proprietary drivers instead of mass media drivers.
Jan 28, 2009 | Cobra DC325 Digital Camera
Pictures do not show up on SD card
Have you successfully used this card in this camera before? If not, you may have a new card that is too large for this camera to use, not all cameras can use the newer large cards. If you have successfully used this card in the camera before, you need to reformat it IN THE CAMERA to make sure the file structure is correct for this camera. When you reformat a card all the data on the card is lost, so be sure you have copies of all the photos backed up on your computer before you reformat the card!
Dec 12, 2008 | Polaroid PhotoMax PDC 3070 Digital Camera
I1032 Camera Driver for Vista?
To get going, insert the CD that came with the camera into your computer. Instead of choosing the autorun, install the DVIX application before commencing to install other desired applications. With the above sequence,you will be able to install the camera driver and will be able to download your pictures into your computer. Howerver, during the download, the computer will ask you if you will want to scan your camera and fix problem or continue, chose continue that is don't scan. Enjoy your camera and computer interface.
Mar 20, 2008 | Cameras
I need vista driver
Here is a link for your driver. I think it will work.
try this
This link will open the download page, select your model and download the driver you needed.
Thanks
Iqbal
Mar 16, 2008 | Kodak EasyShare CD33 Digital Camera
I lost the cd needed for installation of my GE MiniCam Pro HO98756 Webcam!!
Did you follow explicitly the instructions on page 6 - 8 of the manual of not you will probably need to delete the driver remove the Cameras USB connection from the computer, reboot and perform the install step by step with the instructions.
Is your computer running Vista -- then use the new driver to install.
Manual
http://www.jascoproducts.com/support/download-files/98756.pdf
Drivers
not Vista
Vista
http://www.jascoproducts.com/support/download-files/98756_vista.pdf
Dec 18, 2007 | GE MiniCam Pro HO98756 Webcam
Polaroid PhotoMax PDC 3070 Digital Camera Logo
Top Polaroid Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Lee Hodgson
Lee Hodgson
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
