Question about LG LHD65EBL Dehumidifier
Hi, I have an LG dehumidifier, model number LHD650EBL. I have a hose attached and inserted directly into a drain in my basement, bypassing the water tray. Problem is, my dehumidifier is saying "bucket full"--when I don't even USE the bucket! This unit was purchased new from Home Depot on 3/31/10, I really need it to work, any suggestions before I lug it to a service center? Thanks.
Posted by joanne_penta on
Duane Wong
  • 6,826 Answers
Try to see if operating the float lever by hand can make it turn off the 'bucket full' message. Maybe use a rubber band or tape to keep it in the on position vs. the 'bucket full' off position.
Check to see if the bucket has to be inserted for the unit to operate, and if the bucket has a nozzle to hook a hose up to at the bottom. I have a dehumidifier of a different brand that has this feature that works with the bucket in, but with the drain nozzle on the bucket connected to a plastic tube that leads to a drain for continuous operation without having to empty the bucket.
How is your hose attached to the unit if it isn't attached to the bucket?
Good luck on this repair.
Posted on Jan 16, 2011
Direct drain
2 possibilities: #1The port that you plugged the hose onto need to be drilled so the water can come out and enter the hose. #2 The hose cannot be higher at ANY point than the bucket. Physics rules apply and the water will always fill the lowest point. Keep the hose low or raise the dehumidifier up.
Jan 06, 2014 | Danby DDR583R Dehumidifier
I need a part(s) which allows the water from the dehumidifier to drain into a hose which goes to a basement drain. What are the names of the parts and where can I order them?
Not knowing which brand and model number dehumidifier you have, makes telling you what parts you need difficult at best. Most dehumidifiers only require a garden hose section, no longer than 5 feet, that connects to rear of the unit. The connection will be a threaded male connection. It is plastic, so don't over tighten it and crack it. It will have a screw off cap, which must be removed to connect the hose.
Keep in mind, most dehumidifiers rely solely on gravity to drain the water thru a hose. So, the hose should slope down from the unit and straight over to the floor drain.
If the above didn't help you, get back to me with the brand and model number of your dehumidifier.
Thanks for choosing FixYa
Aug 14, 2011 | Dehumidifiers
Basement smells musty, fan won't stay on continuous
Barbara, are you running the unit in a continuous mode (i.e Using a hose to drain the unit)? Or is the water draining into the water collection bucket?
If you are not using a hose for continual drainage, the fan will not run constantly. It requires that, for continual operation.
Also, you may have the humidity extraction level set to high. Lower it to 35%. Also, remove and check the air intake filter, as it may need cleaning.
Dehumidifiers that are not Low Temp models have a difficult time operating in basement applications. Because the air temp at floor level is colder than at shoulder level. At temperatures between 40 & 60 degree F, regular dehumidifiers struggle to keep up. Raising it up off the flow on to a sturdy table, counter top, etc that can handle the weight of the unit, plus a full bucket of water can really help.
I hope this was of assistance and thanks for choosing FixYa.
Jul 29, 2011 | LG LHD459EL Dehumidifier
I am thinking of buying the ADER50LP. Can a drain it directly to a floor drain, by-passing the bucket? If so, does it have an external spigot or will I need a hose? Are ADEW50LP and ADER50 LP identical?
You will need to use a drain hose that is no longer than 5 feet. Using a hose relies entirely on gravity. So, the hose must slope downward with no kinks. A short 5' section of Garden Hose works well. The female coupling end attaches to the dehumidifier. It's a very effective way, not to having to stop and drain the tank time it's full.
The ADEW50LP, is a low Temperature Unit, which designed for basement applications.
The ADER50LP, is a standard unit. Used for all applications, other than a basement.
Both have the external drain feature and the same water extraction capacity.
Hope this helped you. Please let me know.
Jun 21, 2011 | GE Ader50ln Dehumidifier
I don't know where the pipe connects to the dehumidifier, the threaded pipe which will bypass the collection bucket. I inherited the unit (sans manual) from my sailor son who used it in his boat.
Jeremy, you will either find it on the back of the unit. It will have a screw off plastic cap on the connection. OR when you remove the water bucket, you will see it inside that cavity, that the bucket is insert into. In both cases, it will look like a garden hose connection. The hose you attach, should not be longer than 5 feet. It relies entirely on gravity to drain.
Hope this helped you. Please let me know. Thanks.
Jun 12, 2011 | LG LHD659EBL Dehumidifier
I attached a hose to the drain hose connector. When I insert it into the drain hole it is blocked by the back of the dehumidifier. What iw the correct way to insert? Can you send a better diagram?
The drain hose connector MUST be attached to the unit, before attaching the garden hose.
First, the connector is attached to the unit. Second, the hose is hand tightened to the connector.
If you haven't been doing it in this order, that's the problem.
Mar 13, 2011 | LG LHD459EL Dehumidifier
LG dehumidifier
I Have an LG Dehumidifier and water has leaked out to the basement floor, it has a hose that drains into the floor
Sep 12, 2008 | LG LHD65EBL Dehumidifier
Draining Problem
Mine had the same problem. Make sure the unit is tilted towards the side with the hose attached (hose side low)
Aug 02, 2008 | Whirlpool Gold AD70USS 70 Pint Per Day...
LG LHD65EBL Dehumidifier Logo
498 people viewed this question
Top LG Dehumidifiers Experts
jdthefixer
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
