CIPHERLAB 8000 Series Handheld Mobile Computer Logo
Question about CIPHERLAB 8000 Series Handheld Mobile Computer
My cipherlab 8000 has the problem about screen display.I don't know what's the actual cause. After i'm not using it almost 1 month without remove the a battery out. When i'm open it again , the screen was fade down ,the led light not work any more. Could you please find out the solution for me. Thank you very much. ,Warat
Posted by warat agatwipat on
Dag Sandgren
  • 4 Answers
I assume you mounted new batteries or charged it now.
The most common is contrast is adjusted by mistake by user.
But display could fade if battery have bad status when its turned on and its turned off due to bad batteries. This happen very seldom.
Adjust contrast by press the FN/ALPHA-key and simultaneously press UP or DOWN keys. This adjust contrast back!
Posted on Jul 02, 2015
electronic & computer repair& servicre
  • 12,061 Answers
Hi, there are two possibilities, One the main battery has gone bad, this is common, the only way to tell is to replace it. Two, on the main board, there is sometimes a small battery, this battery can sometimes leak, etc, or have gone bad. Replacement, if there is one, usually fixes it.
Posted on Dec 14, 2010
  • 1 more comment
  • Anonymous Feb 22, 2012
    I have the same problem.I replaced the main battery but the screen is also fade down.
    I have the same problem.Replaced the main battery but the screen is also fade down.What to do?
  • Randall Hatfield
    Randall Hatfield Nov 07, 2013
    I had the same problem with my cipher lab 8000 with the screen faded and hard to read. First make sure you have good batteries 2 AAA in your scanner. Turn the power on, hold down the FN (function key)/ alpha key located in the bottom left of the key pad , while holding the function key press the up/down arrow for desired contrast, this will adjust the text brightness.
Hi, my Cipherlab 8000 turned off while I was working and now, after so many attempts, it doesn't turn on anymore, what can I do?
what is it? is it a computer posted to computers.
huge 200page manual (first google hit )
its a system , not 1 thing, right,
a host and mobile computers.
which of these is your system.
Receiving in Retail Price Check Product labeling & Tracking Shelf Product Replenishment Mobile Point of Sale (POS) Mobile Inventory Management Order Picking & Staging Work-In-Process Tracking Material Flow Control Transportation & Distribution Warehousing Asset Management
what part of the system are you hands touching, IDK>
My CipherLab 8000 not scan the barcode.laser are open but can't scan.Could you please find out the solution.Thank you.
May be some one doing by mistake disable for all types of bar code ( not enabled ) or all sympologies.
How do I insert comma into the scanned data of a cipherlab 8000?
If you using Forge, you could chose between comma or dot for decimal inputs in the latest versions of Forge.
Earlier just a dot were available.
Cipherlab cl8200 timeout error? when exporting to hand held?
9f76079d-6fa0-4db9-9587-a2e27f8ce81a.jpg in the lookup section . select the following
that should solve the timeout problem
1helpful
I have a Cipherlab scanner 8001, when i connect it to a linux computer, it doesnt download it gives me a Time out error, but when i connect a Cipher scanner 711 to the same COM port it works. Please advice...
OK,you indicated COM1 serial port is working on the a Cipher scanner 711.
Please check the communication setting on the Cipher scanner 711.
The most popular setting are
AUTO BAUD RATE
or
9600 bps 8 bits N for no parity check and 1 for check bit.
Short for as
9600 8 N 1
Check the setting on the Cipher scanner 711 communication speed and make set the Cipherlab scanner 8001 to the same rate.
MAKE SURE YOU RE-BOOT the Cipherlab scanner 8001 before re-try.
Please keep me up to date on the fix via email.
2helpful
Hello! I have a problem when programing the CipherLab 8001-C Application Program (AG8000N.exe). The download start (terminal bip) and after 3-4 sec show "Download Complete" but the terminal show the...
Cipherlab has technical support available - I'd recommend getting in touch with them. The Cipherlab global site is: http://www.cipherlab.com/default.asp - you can choose your region, then support or the contact link.
Top CIPHERLAB Computers & Internet Experts
Tom Chichester
Brett Duxbury
Brett Duxbury
Larry Ng
Larry Ng
Are you a CIPHERLAB Computer and Internet Expert? Answer questions, earn points and help others
