Question about KitchenAid KFC3100 Chef's Chopper Food Processor
My chef chopper bowl has a crack in it would like to find a replacement bowl model KFC3100CA
Posted by whitemaw on
Anonymous
    Problem Solver:
  • 3 Answers
Go to http://www.appliancepartspros.com/ and search by model number. They have everything you need at good prices. They have saved me lots of $$$ on various replacement parts as they are usually the cheapest because of tax and shipping. Hope this helps!
Posted on Jan 04, 2011
Kitchen aide chefs chopper Model KFC3100ER2 does not always turn on when pulse button is pressed
You need to replace either the bowl or the lid. Either the lid is not pushing the bowl mechanisms far enough or there is too much lost movement in the bowl part.
Sep 14, 2013 | KitchenAid KFP715 7 Cups Food Processor
Kitchenaid kfc 3100
Probably the mechanisms in either the bowl or the parts of the lid that engage the bowl mechanisms.
Aug 31, 2012 | KitchenAid Chefs Chopper KFC3100 3 Cups...
I cannot remove the blade from my 3 cup chef chopper
The manufacturer's website does not provide any information that would suggest that there is a release or a particular technique for removing.
If you were forced to leave in place after using it is possible that food residue has dried and is contributing to the problem. Suggest you try adding some warm soapy water to the bowl and let soak for 10 - 15 minutes.
Pour off the soapy water and then while wearing a protective glove see if you are able to remove the blade with some careful wiggling and twisting.
The following resources may be useful references in the future.
Owner's Manual:
http://useandcares.hamiltonbeach.com/files/840112600.pdf
Parts Lists:
http://www.kitchenaid.ca/assets/pdfs/literature/Repair%20Part%20List%20-%208204526.pdf
Mar 01, 2011 | KitchenAid KFC3100 Chef's Chopper Food...
I need the replacement (plastic) bowl that has the spring in it for a kitchen aid KFC model 3100OB Serial #WJM2497882 chopper
I always mention 1800Parts.com because they get us everything. Check their website or call them and see if they can get you the part. Tell them we sent you and they might give you a discount.
Sep 20, 2010 | KitchenAid KFC3100 Chef's Chopper Food...
Need a replacement bowl for my Kenwood Chef
I have an Excel that has the D shaped bowl but the base of it is round. Since the Excel does have a round base you can fit any existing bowl onto the Kenwood including their newer stainless steel bowl.
Mar 13, 2009 | Food Processors
On the KitchenAid 3 cup Chef's Chopper, How do you lock the blade so I can turn on the chopper?
The Kitchenaid food choppers have a few safety features implimented. If the unit is not assembled properly, this may prevent the unit from turning on. Proper assembly is below:
If it isn't all ready, please disassemble the entire unit. This means removing work bowl, work bowl lid, and blade.
Start by placing the work bowl onto the motor base. The work bowl handle should be facing at 9 o'clock, which is out to your left. Rotate the handle downward until it locks in at the 6 o'clock position, which will lock over the center of the button panel.
Repeat the process with the work bowl lid. The blade does not need to be present for the motor to engage, if this is an assembly issue.
Dec 29, 2008 | KitchenAid KFC3100 Chef's Chopper Food...
Sunbeam Food Processor/Le Chef 14-11, 14-1A
My mom gave me her Le Chef that had several cracks in the handel and also the place where the handel attaches to the bowel with a screw was broken. I Used Loctite super glue for the crackes in the handel and a loctite epoxy putty that can be molded into the shape needed to fix the place where the screw attaches the handel to the bowel. After the putty set I sanded it to refine its shape and matched the screw hole in the bowel with the handel then drilled a small polit hole in the handel. I slipped the handel into the slot in the bowl and attached it with the screw and now I have a good as new Le Chef.
Jun 23, 2008 | Food Processors
How do i print manual
Manuals for Kitchenaid appliances may all be downloaded and printed from Kitchenaid.com.
On the main page, click "Customer Care" in the upper-right hand corner. Then click "Locate Manuals and Guides."
You will need to enter your model number exactly as it appears on the bottom of the appliance. You should find the model number on a white sticker.
Feb 07, 2008 | KitchenAid KFC3100 Chef's Chopper Food...
KitchenAid KFC3100 Chef's Chopper Food Processor Logo
135 people viewed this question
Top KitchenAid Food Processors Experts
ThaMp3Doctor
ThaMp3Doctor
Zhareese
john h
Are you a KitchenAid Food Processor Expert? Answer questions, earn points and help others
