Did you try (800) 582-9359 ? I dont see a full size cribs in the recall as you noted, just the porta-cribs. The metal slat the releases the drop side is called a Kick Rail and it was a common design a long time ago. Remember that dropside cribs are now considered dangerous and illegal to sell, via the CPSC website. If you have decided to continue use of the crib, simply create an "L" bracket under the bottom of the dropside that will prohibit the side from lowering. Also note that the CPSC says any crib over 10 years old is considered unsafe. I have personally spoken with Gerry/Huffy in the last 6 months so you should be able to reach them. Please respond if not and I will follow up. Good luck and be safe.
Evenflo bought Gerry and you can try them at 1-800-233-5921 8-5PM EST Mon-Fri Otherwise, you may post exactly what part you need and one of us may have it in a parts bin.
Every piece of equipment has a model number you can check this link https://plweb.evenflo.com/replacement_parts.aspx You should be able to get replacements. You can also call them they would be happy to find a replacement for you. These things get lost from time to time or just get worn and torn. Here is a number for you to call.
US: 1-800-233-5921 Canada: 1-937-773-3971
Hours of Operation Monday - Friday 8:00 a.m. – 5:00 p.m. Eastern Standard Time
These assembly instructions are for Evenflo crib model 9021
manufactured in 1999. When you click on the link, click on the image,
select "view raw image" and you will be able to use magnifier to zoom
in.
SEE IF THIS HELPS GOOD LUCK: These assembly instructions are for Evenflo crib model 9021
in.
Hello, we moved and the hardware for the Delta model 4960 disappeared. Where can I buy another set so the baby is happily back in the crib???? Help. [email protected] Linda
