But once a old once I unplug it from the wall it resets itself it's the best way to do it that I found
The OD "fault" code on the display means "OPENED DOOR". This does not mean the machine thinks the door is open, but it has not recognised that the door was opened prior to starting a wash cycle. This could be because you filled it, then turned it off before turning it back on to run the cycle. Often you can clear this "code" by simply opening and closing the door again and starting the wash cycle as normal. If this doesn't work then there may be a fault in the door lock switch or the control board.
Hope this helps.
Regards,
BElectric
