Question about Paragon Amf 7008-00 Timer 7 Day 120 Volt Timing Motor
Lost instruction manual. How do I progam my Paragon Electric timer Model EC7004/120
Posted by dmank155 on
Anonymous
Link below has Paragon EC7000 series timers and manuals
EC7004/120 is 7-day programmable timer.
Single channel 120Volt SPST NEMA1 indoor timer.
Program up to 16 events per week
http://waterheatertimer.org/Paragon-timers-and-manuals.html
EC7000 series programming manual shows wiring, explains keypad, has steps for setting current time, and shows 24 steps for programming timer. Plus troubleshooting.
It is impractical to write out those steps when they appear in manual.
http://waterheatertimer.org/pdf/Paragon-EC7000-04-05-manual.pdf
EC7000 series Sell sheet with model numbers
http://waterheatertimer.org/pdf/Paragon-EC7000-sell.pdf
Description of model numbers at Uni-line
http://www.uni-line.com/modules/catalog/SearchResults.aspx?catName=19030&pID=19029&mode=categorysearch
Posted on Dec 01, 2010
Paragon Model 632-00 Manual
Copy following link:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#632
632-00 is 120Volt defrost timer. Electric heat defrosting with fan delay.
Hot connects to terminal 4
Neutral to terminal 6.
One wire from Fan, compressor, heater each connect to terminal 6, and other wire connects to one of the other terminals depending on electric heat, hot gas, or water spray defrost
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 24, 2013 | Paragon Hardware & Accessories
Is it possible to buy the timer motor for a Paragon electromechanical timer (Model 7008-20, 208-240 V, 60 Hz)? The timer motor part number is M3100, and the timer is 208-240 V, 3 watt 60 Hz.
1) Paragon is no longer making timers or parts except defrost timers.
7008-20 240V 24-hour mechanical timer is not a defrost timer.
Link below shows folks who might still have Paragon parts
http://portalgb.knowledgebase.net/display/1/index.aspx?c=15121&cpc=XobrEdQ5Lsnv624T2PBS4Exx6S5VyiL7gw3am4YYt6&cid=13013&cat=&catURL=&r=0.485034763813019
2) To see Paragon timers and manuals:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#7000
3) If you want to buy new timer: Intermatic cross-reference guide shows T7802B is correct replacement timer
http://www.intermatic.com/customer%20service/competitive%20cross%20reference.aspx
4) Electric supplies online shows T7802B 4 pole 2NO/2NC
http://www.electricsuppliesonline.com/int7tidp20t.html
5) Manual for T7802B
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/t7802b%20-%20english.ashx
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 09, 2011 | Paragon Indoor Electromechanical Timer...
I need to get some trippers for my paragon hot water heater timer i believe it is a 4004-20....any suggestions where i might can purchase them....thanks bill
4000 series Paragon timer uses X2772 tripper
To check your model:
Midnight electric sells X2772 tripper
http://midlightelectric.com/firex/acatalog/FIREXPARAGONROBERTSHAW_X2772.html
That being said,
According to e-mail I got from Paragon last month, Paragon is no longer making timers or timer parts. Except for defrost timers. 4000 series is not a defrost timer.
This explains why some sellers of these trippers are asking $50 or more for $3 pair of trippers.
To change your timer to Intermatic.
Refer to Intermatic cross reference:
Dec 06, 2010 | Hardware & Accessories
I have a model 7005 outdoor timer ,brand new but no instructions to proceed with settings .Can you help me?
72d1511.jpgParagon 7000
Paragon 7005 is a heavy duty 7-day mechanical timer that can handle 4 loads. It is DPST. One of two wiring diagrams applies to this timer:
1d6e8ec.jpgThe question is the the timer clock motor is 120V or 240V?
36b7dc9.jpgParagon EC 7000 is a 7-day digital timer with 16 set points per week
Manual for EC7000
http://waterheatertimer.org/pdf/Paragon-EC7000-wire.pdf
Please re-post your questions as you start sorting out which timer you have.
Paragon is improving their site so there is less confusion over model numbers and functions. but information about the 7000 are still sketchy.
Oct 15, 2010 | Paragon Hardware & Accessories
Timer is OK but I have lost the setting instructions, where can I get a new set
http://www.icca.invensys.com/paragon/P100_series.htm
Click on 'download manual' >> it is a 2-page pdf file, you need adobe reader
Sep 09, 2010 | Paragon 4001-0G Defrost Timer
Paragon Amf  7008-00 Timer 7 Day 120 Volt Timing Motor Logo
5,257 people viewed this question
Top Paragon Hardware & Accessories Experts
Gene Haynes
jdthefixer
Are you a Paragon Hardware and Accessory Expert? Answer questions, earn points and help others
