Question about RCA 27F530T 27" TV
Need to change channel to 73 so my dish tv will work, it seems the highest channel tv set will go is 69
    Novelist:
  • 123 Answers
We would be happy to help with that. Some TV's do not havethe ability to go as high as channel 73; this may be the case for your (enterbrand here). We would recommend changing the channel that your DISH Networkreceiver outputs the picture for your TV2. Start by pressing the"Menu" button, from the main menu press 6 for "SystemSetup", then 1 for "Installation", and then 5 for"Modulator Setup". Under TV2 we are going to change the mode to"Air", the channel displayed beside it should change to 60, selectdone on the right side of the screen to save the changes. Now change thechannel of your TV2 to 60 and you should get the DISH Network programming. Wehope this helps. Thanks so much for being a valued DISH Network customer! Phillip Chang DISH Network Customer Service Representative
Posted on Mar 02, 2011
pgh_pa_guy
  • 2992 Answers
SOURCE: I have a Samsung 27
Set the TV to cable tuning mode and use that channel 73. You have it set for air now so it can only tune to channel 69.
Posted on Apr 26, 2009
I'm tring to change my sylvania tv 6424tfs to channel 73 it's not letting me
It sounds like the main system control memory IC to your set is faulty. Even though, this IC is very small in size, and very cheap to buy, the function to it, when the TV is switched on is great. It will be best to contact any service technician in this case. To get some details, http://electronicshelponline.blogspot.com/ Pull up older posts.
Dec 10, 2013 | Sylvania 6424TFS 24" TV
Why can't I get tv to channel 73 for dish hookup
The set returned when power removed to the AIR band which only goes up to 69.
Go into customer menu and change from AIR or ANTENNA to Cable or CATV.
Jun 17, 2012 | Televison & Video
Hi, my Phillips was hooked up and working fine directly to the DISH receiver using the HDMI 1. I moved and had to put the DISH receiver in another room and ran a coax cable to where the TV is now using...
Hey murphypat321,
Sounds like the TV may need to be on ch 73 cable rather than 60 air. Try switching the TV to 73, if it goes to 69 then put back on 60, if goes to 73 good. Once you have that set go to your TV1 and bring up the menu. Go to System Setup (6) -> Installation (1) -> Modulator Setup (5) and change the TV2 setup to either cable if on 73 or air if on 60 and the picture should come in if everything's hooked up.
Hope that helped! You can email me at [email protected] if the problem persists.
Tommy Faust
DISH Network
Mar 09, 2011 | Philips 42PFL5332D 42 in. LCD Television
I change the tv # 2 and now I can't get to set the signal
Hey! My name is Becki Barned, and I am with Dish Network customer service! You have already gotten this issue resolved, but here are some steps in case you haven't! On tv2, try channel 60 and then 73. if that doesn't work, try to go to tv#1, press menu 6-1-5. Here, change (under tv2 out) the MODE setting from AIR (if it is on air) to CABLE, and vise versa. If the tv cannot go up past 69, make sure that the MODE is set to AIR. That's changing the setting for the TV#2, and with a new tv, this will usually fix it! Blog if any troubles!
Aug 21, 2010 | DISH Network 322 DTV Receiver
Our power went out last night and I cannot get the tv set back to channel 73 which is the channel set for our DISH network. It only goes to 69 then starts over at Vid 1 and Vid 2.
Channel # 73 may have been deprogrammed from your TV's memory. Follow the instructions in your manual to add the channel back in.
Jul 28, 2009 | Audio Players & Recorders
I have a Samsung 27" TV and need to set it on channel 73 to get a picture from my Satelite Dish. The highest channel the tv goes to is 69.
Apr 26, 2009 | Samsung TXN2771HF 27" TV
Settting tv to a higher channel for cable`
Most TVs have a choice of air or cable in the menu portion of the tv. press menu go to setup and from there you should see an option that says air/antenna or cable. You will have to either toggle to get the air selection or highlight it. Then you should be able to get to channels you need.
An easier solution may be to go to the Dish receiver that controls the image on the tv you can't get to 73. With tv and satellite on (make sure both green and blue lights are on) press on your Dish remote #1 with the green tab on the bottom the following sequence: MENU - 6-1-5. tHIS WILL TAKE YOU TO THE MODULATOR SET UP PAGE. Move the highlight from cancel to the mode section an highlight AIR and press select. Then move the highlight back to the right to DONE and press select. Press cancel three times or view live tv. then go to the other tv and put it on ch 60.
Hope this assists you.
Sep 09, 2008 | Symphonic ST420FF 20" TV
Does tv go higher than channel 69
In 1998, UHF-69 was highest channel. you need that TV which has today's technology.
May 29, 2008 | GE Televison & Video
Switching from TV to CATV
it sounds like the tv is already in cable mode, and that it is a older tv. some older tv's will only tune in so many channels. yours going up only to channel 69. if you have the remote for this tv, try punching in channel 73. if it doesn't tune in, then the tv will not recieve channel 73.
good luck
wg
Feb 05, 2008 | Emerson EWC27T3 27 in. TV/VCR/DVD Combo
TV Channels
SOUNDS LIKE WHAT HAPPENED TO ME WHEN THE CHANNEL GOT ACCIDENTALLY BLOCKED AS AN UNUSED CHANNEL CHECK YOUR MENU ON REMOTE FOR ADD AND REMOVE CHANNELS AND RELOAD THAT CHANNEL AS INSTRUCTS IN MANUAL FOR THE TV
Jul 17, 2007 | Emerson EWF2703 27" TV
RCA 27F530T 27" TV Logo
403 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
