The e74 Xbox error's principal cause is overheating, due to excess heat causing damage to various components, and eventually major malfunctions in the hardware of your console. Why is this heat able to build up and cause damage that leads to the Xbox 360 e74 error? This is actually due to cramped case design and a lack of cooling devices such as fans and heat sinks. Although overheating is ususally a problem for all electronic devices, the Xbox 360 does seem to suffer particularly badly from this issue. unless you have a bit of technical knowledge than the best thing would be to A) fix your Xbox e74 problem by sending your Xbox 360 back to Microsoft for repair or B) buy a new one. there is no easy way to permentaly fix it without taking your xbox apart and the "towel trick" which is where you wrap your xbox in a towell power on until it overheats and shutsdown is only a temporary fix and will cause major damage to your xbox in the long run. fixing yourself consists of stabilizing the heat shields by removing the old brackets and replacing them with new heat paste and bolts so the best thing if you are dedicated to doing it yourself would be to probably buy a manual online. you shouldnt need to pay anything over $30 and make sure you get a full manual because alot of them only deal with the "red ring of death" (which is three red rings)
hope this helps
Back to the top
CAUSE
This problem occurs when the Xbox 360 console experiences a hardware failure.
Back to the top
MORE INFORMATION
Step 1: Confirm the E74 errorTo verify that your console is displaying the E74 error message, follow these steps:
1.
Turn off the console.
2.
Turn on the console.
3.
Verify that your console displays the E74 error message.
Back to the top
Step 2: Submit a console repair requestIf you are experiencing this problem, you can submit a console-repair request online by using the links in the "Additional support" section.
Back to the top
Additional supportIf your console continues to display the E74 error message, it requires a repair. There are no additional troubleshooting steps. To start the online repair process, click one of the following links:
In the United States
http://support.xbox.com/support/en/us/nxe/registerdevice.aspx?step=repair (http://support.xbox.com/support/en/us/nxe/LiveIDSignIn.aspx?redirectUrl=http://support.xbox.com/support/en/us/nxe/registerdevice.aspx?step=repair)
Outside the United States
http://www.xbox.com/support/ (http://www.xbox.com/support/)
Note Online console repair service is currently not available in all countries and regions.For more information about how to contact Xbox support directly, please visit the following Web site:
http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) Microsoft covers repairs for the E74 error for a period of three (3) years from the original purchase date of the console. If you are outside the initial three-year warranty period, you can still receive console repair service from Microsoft for a fee for the E74 error. For more information about this repair process, click the following article number to view the article in the Microsoft Knowledge Base:
969905 (http://support.microsoft.com/kb/969905/ ) About the E74 warranty extension for Xbox 360 consoles
Back to the top
References/Links
If one light around the power button on your Xbox 360 console flashes red, there are additional steps that you can try. For more information, click the following article number to view the article in the Microsoft Knowledge Base:
907536 (http://support.microsoft.com/kb/907536/ ) One light flashes red on your Xbox 360 console
