Question about BenQ FP737S-D 17" LCD Monitor
The monitor green light is on but the screen is blank.
2 Suggested Answers
6ya staff
SOURCE:
budmrtn
Bud Martin
  • 11361 Answers
SOURCE: Monitor stopped working, blank screen
First place to check will be the power supply section, look for bad caps (bulging top/bottom), post back what you see so we can guide you further, see example of failed monitors due to bad caps, lamps: http://s807.photobucket.com/home/budm/allalbums
Posted on Feb 06, 2010
Acer AL1912B, the screen is blank and the green
The problem ca be bad back light inverter circuits, bad power supply because of bad caps, bad lamps. More likely to be bad caps, see example of failed monitors because of bad caps: http://s807.photobucket.com/home/budm/allalbums
Jan 18, 2010 | Acer AL1912B 19" LCD Monitor
Desktop screen is blank even when the cpu and monitor indicator a
It looks like issue with either mother board or processor.
open the box and remove all memey and power it on. if it makes a beep sound, there is no issue with processor, else we suscpect processor. If it make beep sound, it might be mother board issue. And for checking monitor working condition, remove monitor data cable and see no cable connected messages comes in monitor or not
Oct 13, 2009 | Dell Computers & Internet
Screen is blank. Green LED power light is
Might be your graphics card, try swapping it out for a new one and see if that works
Oct 09, 2009 | Dell E173FPb 17" TFT LCD Monitor
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
Screen goes blank within 1 second of being turned on
Bad capcitor in the psu would cause this to squel and even pop so have it looked at you be glad you did.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 23, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Blank screen
This looks like a problem with the video card or the power supply to the monitor. Try connecting a different monitor and if you still face the same problem then probably you may need to have a look at your video card or its connection in motherboard
Feb 01, 2009 | ViewSonic A90f+ 19" CRT Monitor
SVA Color TFT LCD is white on start up but goes blank.
when i turn the computer on the light on the monitor blinks green but i cant get it to turn on..i have a black screen.
Jan 16, 2009 | Computers & Internet
Monitor screens blanks a few seconds after I switch on computer
Took the cable connecting the monitor to the computer and reversed it, this seems to have worked!
Dec 21, 2008 | Sony SDM-S74 17" LCD Monitor
Green light blinking screen blank
Hi Suzee,
Is the green flashing on the tower or the monitor?
If it is flashing on the monitor, then it might be tht the monitor is not gettign signal from the tower.
To check, disconnect the monitor from the tower and check the monitor. If you get a msg on the screen like no input signal or check video cable, then 99% monitor is fine.
Check for the power supply light at the back of the tower.
Disconnect everything from the computer and then press and hold the power button on the comp for about 30 seconds.
Then connect the cables and check if it is working.
Jan 14, 2008 | Sony SDM-S73/B Monitor
Blank screen
its cheap buy a good one!!!!!!
Dec 22, 2007 | Computers & Internet
BenQ FP737S-D 17" LCD Monitor Logo
26 people viewed this question
Top BenQ Computers & Internet Experts
Ekse
Joaquim Martins
Karan Sethi
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
