I just read your instructions, very clear, thank you. Now, do I switch the lamp on when I program it or to I leave it off ? ... Thank you for your assistance
Hope this helps; also keep in mind that your feedback
is important and
I`ll appreciate your time and consideration if you leave some
testimonial comment about this answer.
is important and
DTC P1780 - Transmission Control Switch (TCS), Transmission Control Indicator Lamp (TCIL)
The Transmission Control Switch (TCS) is a momentary control switch.
When the switch is pressed, a signal is sent to the powertrain control
module to allow automatic shifts from first through fourth gears or
first through third gears only. The PCM energizes the Transmission
Control Indicator Lamp (TCIL) when the switch is off. The TCIL indicates
overdrive cancel mode activated (lamp on) and Electronic Pressure
Control (EPC) circuit shorted (lamp flashing) or monitored sensor
failure.
Hope this helps and just keep in mind that your feedback is important
and I'll appreciate your time and consideration if you leave some
Here's the general rule of thumb for cooking temperatures for meats. Remember though, you cannot leave the thermometer inserted in the meats while cooking. It's only for Instant Read.Always insert it in the thickest part of the meat away from any bobes.
OBTAIN ALL REMOTE TRANSMITTER. TRY THIS PROCEDURE.FASTEN SEAT BELTS AND CLOSE ALL DOORS.TURN IGNITION SWITCH FROM OFF TO ON 4 TIMES WITHIN 6 SECONDS.SWITCH IGNITION OFF,ACOUSTIC SIGNAL WILL SOUND AND SYSTEM WARNING LAMP WILL ILLUMINATE INDICATES CORRECT PROGRAMMING.WITH IN 10 SECONDS.PRESS AND HOLD ANY REMOTE TRANSMITTER BUTTON. WAIT FOR ACOUSTIC SIGNAL AND SYSTEM WARNING LAMP TO FLASH INDICATES CORRECT PROGRAMMING. TO PROGRAM ANOTHER REMOTE TRANSMITTER, REPEAT ABOVE PROCEDURE WITHIN 10 SECONDS.TO EXIT PROGRAMMING MODE,TURN IGNITION SWITCH TO CRANK OR WAIT 10 SECONDS. IF THIS PROCEDURE FAILS YOUR IGNITION KEY WORN OR IGNITION SWITCH RING COIL BAD.
Press the MESSAGE button. It will light the lamp on the receiving station and when they press MESSAGE it will show that you called.
If you're trying to program "voice mail", then there are specific instructions to setting Call Forward No Answer or just dialing into the VM sytsem and dialing #6 and their extension to leave a direct message.
Epson programmed their printer to monitor the waste ink counter and
your printer has reached the maximum value allowed, you have to reset
your printer to clear the waste ink counter.
it's a simple switch out, first make sure your set is unplugged, open the panel concealing the lamp, unscrew the door, unscrew the lamp, pull it out straight towards you it is attached like an outlet plug, carefully switch it with the new one be sure not to touch the lens, screw in tightly replace the compartment door then the panel and your done....good luck }:)
