Question about Sharp RRMCG1687PESA Remote Control
Code for remote control, Sharp Aquos 32" to motorola dcx3200 cable box
Posted by drrech10 on
5 Related Answers
Anonymous
SOURCE: Programming the Acquos Remote
I got a a sharp LC-32D43U and for my motorola cable box i use hte code 31 from jerrold, i take it from the manual and i got it tryin every single code unti i get one that works.
Hope it works for you
Posted on Oct 21, 2008
jeffrey gallagher
  • 42 Answers
SOURCE: Sharp Remote Control Problem
trying removing the batteries and reinstalling then the reset the remote and then tell me if it works if you have lock the parental function on sould like
Posted on Jan 04, 2009
Anonymous
SOURCE: lc-46d43u aquos lcd tv
The remote code 31 worked on my Motorola cable box.
The REmote is for a Sharp LC-32GP1U
The code was listed under one of many for Jerold. I entered codes one by one testing the secondary power button each time.
Code 31 works fine.
Posted on Feb 26, 2009
Anonymous
Input code 0093 into your Comcast remote. Here's a link for the how to: http://www.comcast.com/MediaLibrary/1/2/CM/VanityURL/documents/comcast_dvr_remote_manual.pdf
Posted on Mar 01, 2009
Anonymous
SOURCE: Sharp TV (LC52D64U) remote control Comcast cable (DVR) box ?
I had the same problem with my remote. I would enter the code and there would be no response from the remote. I looked up the manual for the other comcast remote and the codes are 5 digits instead of 4. Try codes 10093 or 11602. The reason why there is no response from your remote is because it is waiting for you to enter the last digit of the code. Hope this helps.
Posted on Aug 11, 2009
Aquos remote programming for rcn
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Aug 15, 2014 | Sharp AQUOS LC40D78UN 40-inch 1080p LCD TV...
Hi, I have a problem finding a code for my motorola DCX3200 with my universal remote control(cox.) All the other televisions in the house worked, but I can't get this one to respond at all. I have an LCD...
Here is the user guide for the Motorola DCX3200 in PDF format just in case you need it.
Now then here are some Codes for your Cox Universal remote. I understand you have tried some already but just in case you missed any.
Samsung 0060, 0030, 0178, 0019, 0056, 0032
Also give this a try.
  1. Turn on the TV, VCR, DVD, or entertainment center that you want the remote control to control.
  2. On the remote control, press the appropriate mode button for the device once.
    Television TV
    Stereo amplifier or receiver AUX
    DVD, PVR, VCR DVD
  3. Press and hold the SETUP button until the selected mode button blinks twice, then release the SETUP button.
  4. Using the number keys, enter 9 - 9 - 1.
    Result: The selected mode button blinks twice.
  5. Aim the remote control at the device, and then press the POWER button once.
  6. Press the CH+ (or CH-) button one or more times until the device turns off.
    Notes:
    In search mode, the remote control sends IR codes from its library to the selected device, starting with the most popular code first.
    If, while pressing the CH+ button, you inadvertently pass the code, press the CH- button one or more times until the TV turns on.
  7. Press the SETUP button once to lock in the code.
  8. To search for codes for other devices, repeat steps 1 through 7.
Hope this helps, give me thumbs please!
Aug 23, 2010 | Televison & Video
Sharp Aquos tv remote Programming code for Pace(Mediacom)cablebox
Check the cable box for the manufacturers name and see if that isn't listed in your owners manual.
Mar 31, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Remote Codes for Motorola Cable Box DCT700/US
I have run into this problem with my Sharp Aquos as well. This is not necessarily a code problem but an interference problem.
If you take your hand or a thick book and sort of make a hood over the area of the sensor on the cable box and place the remote right up close to the sensor this will help let you know if the remote and the box are working with the code. Also might try turning off the TV or unplug the TV to test and make sure the remote will turn on the box.
Next thing after you determine this is how to block the interference and be able to use your remote. What we did is placed the Wii on top of the box over the area of the sensor and this seems to have done pretty good.
Good Luck ....
Jan 04, 2010 | One For All URC-9800 LCD Remote Control
Dec 01, 2008 | Sharp Remote Control
There is a code out there to try.  The code would be 47.  Just follow the steps in your manual on how to program this box and you should be able to go from there. Can't garantee that it will work as that code came out with the newer tv but it should work.
Nov 08, 2008 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Lc-46d43u aquos lcd tv
Code 31 works fine.
Oct 28, 2008 | Sharp LC-26D6U 26 in. LCD Television
Jul 27, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos 32"
TV is under warranty. Get a tech to look at it. It could require a new IR sensor, a firmware upgrade or a system reset that only a tech can do called an Industry Initialization that is in the service mode only
Jun 24, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Can't program remote control...
The code is 11602. BUT, with OPC on it works only until it gets dark. Then I have to place alu foil over the right side of the box to keep it working.
Dec 23, 2007 | Televison & Video
Televison & Video Logo
297 people viewed this question
Top Sharp Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
