Question about Learning Curve Toys Thomas the Tank Engine Track Rider
Need more track for the Thomas the Train Ride-on Battery operated train. Where can I purchase some?
Posted by shough on
3 Related Answers
Anonymous
SOURCE: Peg Perego Thomas Train Track Rider
Hi
Have you tried keep pressing the right hand button down. When you press the button down and hold the press, then the sounds are finished, the trains starts driving. When you release the button the train stops at once.
Posted on Jun 01, 2009
romney2012
  • 156 Answers
SOURCE: Thomas Train
It might need a new wire connection to the motor.
I would contact
http://www.shopjandl.com/
They help me with my ride on toys.
hope this helps
Posted on Jul 22, 2009
Anonymous
ok I have a train the light and sound work, but the train does not move. Used alligator clips from battery direct to motor, then the motor runs. Just ordered a circuit, will post when receive circuit with sound 15.00.
Posted on Jan 22, 2010
Electric train set stop and goes when it goes over certain parts of the tracks do I need to clean the tracks or the wheels and what do I use to correct this issue?
1: make sure all track connections are tight.
2: clean the track using a Green 3M scratch pad
or a track eraser.
3: clean your wheels, some people use smoke fluid
on a cloth, I use alcohol prep pads,. A track eraser
can also be used. there are commercial wire brush
cleaners that connect to your power source.
Nov 05, 2011 | Bachmann Thomas the Tank Engine Train and...
Hi. Need to purchase a battery for train. What retailers carry the battery and what is the cost? Thanks.
41kwnm4q8pl._sl75_.jpg National Products 6V Battery Operated Talking Train with Track
Buy new: $129.99 $129.00
6 Used & new from $127.78
4.3 out of 5 stars
$129.00 & this item ships for FREE with Super Saver Shipping. Details You Save: $0.99 (1%)
In stock but may require an extra 1-2 days to process.
Ships from and sold by Amazon.com.
its better to buy from a recommended marketer, with guarantee
Jan 12, 2011 | RC Thomas the Tank Engine
How do I change the battery in a motorized wooden railway engin for thomas the train
2 options.
1.if its the kind that fits on the wooden track look for a screw (philips/star screwdriver) on the underside of Thomas near his face. The body shell should lift off.you will then see the battery.
2 If it's the plastic blue track you have to squeeze the right center wheel and left center wheel. Thomas has 6 wheels so the 2 center/middle wheels, after squeezing this will then make the top portion pop off.
Jan 10, 2011 | Thomas and Friends Battery Operated Train...
Thomas the Train Ride on Train only goes backwards
Check the battery. It sounds like you have it in, backwards.
Sep 17, 2009 | Toys
Thomas train charge battery has music and sound effects, but does not move?Does it need a new motor
I would contact
hope this helps
Jul 15, 2009 | Peg Perego IGED1084 Santa Fe Train
Hi
May 28, 2009 | Learning Curve Toys Thomas the Tank Engine...
I cannot promise that this is the problem, but this is where mine was broken, and you may be able to fix yours this way.
I was able to remove the plastic around the tender and access the motor. Using alligator clips, I was able to connect the battery directly to the motor, bypassing the circuit board. The motor functioned, therefore the only component that seemed to be defective was the circuit board, located behind the speaker in the engine unit.
As far as I know, the only place to buy a replacement circuit board is from www.tigerimports.com. Search for part number MEVA0024. Cost is around $15 + shipping (around $6 or so).
I should be receiving this part by the end of the week and will report if it fixed the problem.
Thanks for using Fixya. If I didn't help your situation, please DO NOT label this advise as "inappropriate".
Mar 12, 2009 | Toys
The red button on the right must be held down for anything to move. It turns the lights on, makes some train noises, then moves forward. If you don't hold the button down, nothing will happen. Note that when the train is underway, the left red button becomes a train whistle. Otherwise, when the train is not running, that left button produces music. Hope this helps.
Dec 16, 2008 | Peg Perego Vespa Scooter
Peg Perego Thomas the Train Ride-on Music button not working
It could be a bad switch or the music board has a bad contact.
Nov 21, 2008 | Peg Perego Vespa Scooter
Learning Curve Toys Thomas the Tank Engine Track Rider Logo
207 people viewed this question
Top Learning Curve Toys Toys Experts
Marvin
Marvin
Tom Chichester
ray gallant
Are you a Learning Curve Toys Toy Expert? Answer questions, earn points and help others
