https://xbox-experts.com/errorcode/E01/0001/ General info on Error code : 3 Red Lights E01 0001 and how to fix it!. Short circuit in the console/faulty PSU.E-Code / Secondary Error code‎: ‎E01 (No ... Binary/Hex‎: ‎00000001 / 0x01 -> 1 Primary Error code‎: ‎3 RLOD
PROBABLY BAD PHONE LINE, CAN TRY SOME OF THE FOLLOWING
SLOW DOWN THE RX TO 1700
TURN OFF ECM
INSTALL DSL FILTER EVEN IF ITS NOT A DSL LINE
MAKE SURE THE PHONE COPANY KNOWS ITS A FAX LINE
IF ITS VOIP IT MAY NEVER WORK WELL
RESEAT ALL CONNECTORS IN FAX 3900
TRY SETTING TO MMR
MAY ALSO BE PROBLEM WITH THE SENDING FAX MACHINEOR, THERE PHONE LINE
Generally this error(Error 0001) is observed while receiving Fax.The Error Code arises when sender not using G3 Fax Machine.So it is a communication error. I think it helps. Let me know. Best Regards Fixya ExpertChandrashekhar Bhat
open the adf cover you should find a little plastic lever which is a paper sensor it is possible that it is stuck in a open position.be sure that the lever can swing freely
