IBM NetVista PC Desktop Logo
Posted on Nov 30, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tenho uma placa mae ibm 49p1599 mas nao esta entrando o windows xp erro na inicializacao
Level 3:
  • IBM Master 7,733 Answers
  • Posted on Nov 30, 2010
IBM Master
Level 3:
Answers
7733
Questions
0
Helped
1864662
Points
21487
If power to your computer is interrupted while BIOS is being updated, your computer might not restart correctly. The Clear CMOS/Recovery jumper enables you to restart the system and recover the BIOS. To perform a Flash/BIOS recovery using the Clear CMOS/Recovery jumper, use the following procedure: Before proceding, be sure to review the safety information.
  1. Turn off the computer and any attached devices, such as printers, monitors, and external drives.
  2. Unplug all power cords from electrical outlets, and remove the cover.
  3. Locate the Clear CMOS/Recovery jumper on the system board.
  4. If necessary, remove any adapters that impede access to the Clear CMOS/Recovery jumper.
  5. Move the jumper from the standard position (pins 1 and 2) to pins 2 and 3.
  6. Replace any adapters that were removed.
  7. Replace the cover.
  8. Reconnect the power cords for the computer and monitor to electrical outlets.
  9. Insert the POST/BIOS update (flash) diskette into drive A, and turn on the computer and the monitor. The system will begin to beep.
  10. After the update session is completed, there will be no video and the series of beeps will end. Remove the diskette from the diskette drive, and turn off the computer and monitor.
  11. Unplug the power cords from electrical outlets.
  12. Remove the cover.
  13. If necessary, remove any adapters that impede access to the Clear CMOS/Recovery jumper.
  14. Return the Clear CMOS/Recovery jumper to its original position.
  15. Replace any adapters that were removed.
  16. Replace the cover and reconnect any cables that were disconnected.
  17. Turn on the computer to restart the operating system.
  18. You may now want to update the BIOS normally. Refer to the readme.txt file that came with your flash BIOS update.
Boa noite, eu tenho uma roland cx 24 e ela esta dando um erro sempre no meio da impressao, FAN ERRO. O QUE PODERIA SER ESSE ERRO?
http://www.fixya.com/support/t6029680-roland
https://translate.google.com
Oi, n?s temos uma plotter de corte roland camm-1. Ele tem mostrado "erro de ventilador" no visor nos ?ltimos dias, mas se corrige quando ? desligado e ligado novamente. Agora, por?m, quando eu coloco vinil e envio a l?mina para prepar?-la para cort?-la, vem todo o caminho de volta para a direita. Em seguida, enviei manualmente a l?mina novamente usando o bot?o de seta para a esquerda e tecle enter, mas quando envio algo para cortar, o vinil sai alguns cent?metros e para. Voc? tem uma ideia do que pode estar causando isso? Obrigado pelo seu tempo, Kevin
Postado por 2max em 16 de setembro de 2010
Fale com um t?cnico CommentFlag
Mais
de An?ncios
1 resposta
Frank
Colaborador1 Resposta
Eu tive um problema parecido. A quest?o era que eu receberia um aviso de "erro de ventilador", mas o ventilador ainda estava girando quando o erro foi exibido e, em seguida, a m?quina pararia. Levei plotter para minha garagem, tirei as cobertas e usei meu compressor de ar para soprar a poeira do ventilador e das placas de circuito. Quando apaguei o ventilador, uma tonelada de poeira e "pontos" do material socado veio voando para fora. Ap?s uma limpeza completa, eu o re?no e n?o tive o problema desde ent?o - ele funciona como novo. Eu acho que o que acontece ? que o ventilador fica entupido com poeira e pontos e desacelera o ventilador o suficiente para enviar um sinal de erro ao plotter. Sem poeira, sem pontos, sem erros! Tente isso - espero que funcione para voc?!
Postado em 30 de set de 2010
?til 1 n?o ? ?til
Depoimento:
"Muito obrigado pela sua ajuda. Vou come?ar imediatamente."
What is the cause of OKI C3200n fatal error 173
Fatal error code 173:
This error indicates that the Image Drum Up/Down Process is not working properly. The errors are as follows:
140 - Yellow Drum Up/Down error
141 - Magenta Drum Up/Down error
142 - Cyan Drum Up/Down error
Solution:
1. Reseat the Image Drums. Ensure they are in seating properly into the drum carriage.
2. Reseat the Toner Cartridges. Ensure they are seating properly into the Image Drums.
3. Reseat the Contact Sensor Spring assembly and inspect it for damage or mis-alignment. If the springs appear bent or dis-lodged reseat them.
I've unplugged it, replugged it, and still get "service call 173:fatal error"
check mechanical error on your printer by sending it to the actual technician..
Boa noite!! Tenho uma placa mae D845EPI / D845GVSR nao da video, ainda nao tem sistema operecional ia formata-la. mas nao esta dando video ela da tres bips quando tiro as memorias mas com as memorias nao...
Try resetting the BIOS, by using the jumper near the battery from 1-2 to 3-4 for few secs and then move it to 1-2 again and try again if you got video
Boa noite estou descarregando o aparelho mas esta dando erro na transmissa digite enter, mas nao sai disto preciso descarregar ja troquei a bateria qual a solucao?:
Boa noite
Eu tenho um igual e de vez em quando acontece-me o mesmo, como consigo resolver a situa??o, ? precionar a ficha RJ enquanto o PDT est? a transmitir para o PC.
Se pretender tocar mais ideias o meu mail:[email protected]
3helpful
2answers
Não Consigo acessar Serviço de hp plotter Calibração T610. apresentou o Código de 21.1:03 Erro, Substitui uma Estação de Serviço e continuou o Mesmo Erro, Substitui...
helo
Try the following:
Switch the Power OFF from the back of the Printer and disconnect the
Power cord. Check the Primer Tubes. Reconnect the power cord and
power On the Printer.
Perform the Service Station diagnostic test to troubleshoot the problem
further
If the System Error continues, replace the Service Station .
If the System Error continues, replace the PrintMech PCA
Preciso resetar a Bios
Legal..Vamos a situação: Com certeza tenho um virus na BIOS do presario 2200 pq já fiz formatação de baixo nível no HD (0....000)
e quando tento instalar os CDs original winxp recebo informações de disco com defeito, tento com outros winxp originais e a resposta é sempre a mesma, consigo instalar no micro o win98 mas o mesmo fica corrompido, o que fazer..?
Obrigado... Franquelim
9helpful
4answers
Recording
Grupo: Participantes
PLACA DE PCTV ENCORE....?
Meu PC e windows xp...Ele é da microboard...., vem com 1gb 160Hd placa de pctv, AMD... Mas desde quando liguei meu PC pela primeira vez com o vista, não funciona a placa de pctv, depois que eu formatei, e instalei o xp, continuou não funcionando...já tentei de tdo, e naum sei mas o que fazer....
Tenho o programa ENLTV, que veio junto com a placa de pctv que é da ENCORE... quando tenho abrir este programa aparece um erro assim: " Fail to Initialize hardware!ErrorCode#E0601009 "
E no gerenciador de dispositivos, o driver " Controlador de Multimídia " com um ponto amarelo de exclamação..! Tento atualizar o drive com os cds que vieram junto com meu PC, mas nao adianta, já desistalei o drive, e reiniciei o PC, o drive foi reconhecido novamente, mas nao sumio o ponto de exclamação...
Top IBM Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
