I assume your not using a pure sine wave inverter. A lot of electronic devices won't work on a lower cost inverter (modified sine wave) that has a square sine wave, either invest in a true sine wave inverter or don't run sensitive electronic equipment, I'm somewhat surprised you didn't damage the circuit board in the microwave...Below is a link of a inverter that would work if you want to spend the money for one. 2500W 5000 Watt Power Inverter Pure Sine Wave 12V dc 110V 120V ac LCD...
Check your voltage meter, so it measures correctly, probably generate your UPS is not pure sine wave, but a modified sine, then the simple measuring devices to display the wrong value.
Are you using a true-RMS voltmeter to measure the DR's output? The DR's output is modified sine wave, and a cheap average reading AC voltmeter will give you a reading of 90 volts or so. Alternately, if you have an oscilloscope, you can verify that the modified sine wave is around 170V peak to peak. It should alternate in segments of -170, 0, +170, 0... The duty cycle and peak voltages will vary with the inverter load.
- Tom, Sun Electronics International, Miami, FL
Most power inverters supply a modified sine wave output. This is different from the true sine wave you get at home. It's close enough for many applications, but not close enough for many transformers, which is what your laptop power supply is. So the problem is that your laptop's power supply does not work with a modified sine wave input. Some will, some won't. Very common problem.
The output of this inverter (and most others) is a modified sine wave, which isn't quite the same as a true sine wave - like you get from a wall outlet. Unfortunately, most transformers (which is essentially what your laptop power-supply is) require a true sine-wave. Your inverter will work fine for many other 110V applications. You can buy an inverter with a true sine-wave output, but they are more expensive.
I highly suggest you invest in a good quality inverter. For most equipment either pure or modified sine wave is fine. I would suggest you install a line conditioner after a UPS for any computer products. The line conditioner stabilizes the voltage much more closely than a UPS will.
As far as building your own, I've taken apart a lot of UPS models which have a DC-AC converter in them and they are filled with lots of heavy heat sinks, transistors, resistors, capacitors, etc. You can usually find these very cheap since the batteries die but the converter is fine. Check the input voltage of the original unit and start from there to make one easily that has everything already assembled with minor modifications.
I'm not sure what the application is but I will offer the following. As a retired electronics engineer i can say for sure that a true sine wave does not have any harmonics in it. A modified sine wave will have some harmonics and other what I would call " trash content" depending on how it is modified.
