Question about Just Wireless Bluetooth Headset Wireless Headset
My Just wireless blue tooth will not charge. I just bought it yesterday
Posted by erica_kan392 on
Anonymous
I need to know voltage and apms for the charger of the just blue wireless BT-10K, your should use the same, could you email me the info at [email protected] please. it would be of great help.
Thanx alot, steve
Posted on Dec 04, 2010
  • rbbynum Dec 22, 2010
    After charging new BT-10k for 2 weeks, I called Just Wireless (888-753-6957) and learned the following:
    1. This is a common battery issue for them;
    2. Since headset has a LIFETIME warranty, they will exchange broken ones for tested ones after you return their form.. I'm returning my headset and their return form today!
Cellular Innovations HFBLU-FP1 T2 FP1 wont charge
bluetooth - charging mashine problem bring it to recheck the charger
Apr 15, 2012 | Cellular Innovations HFBLU-CX1 Wireless...
Windows vista which USB cable do I need to use a
As far as I am aware the mouse you are talking about is NOT blue-tooth but a regular wireless mouse.
It came with a small wireless dongle that plugs into ANY regular usb port and does not need a cable.
Blue tooth does not usually use cables either as it is a wireless format but different to regular wireless
If your mouse is blue-tooth then you should ensure that your laptop or pc also has blue-tooth.
Should it not have blue-tooth then to use the mouse you would need to purchase a usb blue-tooth adapter. this is not a cable but is classified as a "dongle" you that's true !
This dongle plugs into any regular blue-tooth port on occasion windows will detect and install the required files but some blue-tooth dongles will come with a cd that you need to install.
If this information was useful please click
Aug 16, 2009 | Trust (14694) Keypad, Mouse
Will not let me connect the blue tooth to my phone
ur just a ********..haha nah jk
i got the same problem. help...
Apr 24, 2009 | Just Wireless Bluetooth Headset Wireless...
BLUE TOOTH H 500 NOT GETTING CONNECTED, CEL IS ASKING PIN CODE
thanks
a friend of mine told me the pin code of h 500 blue tooth
which had solved my problem yesterday
any way thanks
ather m.khan
Apr 10, 2009 | Motorola Cell Phones
Wireless radio adapter or card
Try:
G1S - This laptop supports multimodal switching of the wireless and Blue Tooth radios via the key command Fn+F2:
1st press: On both Blue Tooth & WiFi
2nd press: Off Blue Tooth / On WiFi
3rd press: On Blue Tooth / Off WiFi
4th press: Off both Blue Tooth & WiFi
Sep 14, 2008 | ASUS (wifibralinkuay) 802.11b Wireless...
BLUE TOOTH CONECTION PROBLEMS
take it to the store where you bought it from and ahve them assist you with it.
Mar 03, 2008 | Samsung SGH-D900 Cellular Phone
Motorola H550 bluetooth headset
i turned it back intno the store got a refund and went to a different headset. sorry to bother you but i think it had to do with the battery in the headset
Feb 24, 2008 | Motorola Mobility H500 Wireless Headset
Hey, i dont know how to turn the blue tooth on.
after it holds a steady charge, try holding the power button for a few seconds. if you get a blue light (blinking or solid) then its on, obviously. holding most power buttons on bluetooth devices will put them into pairing mode, as soon as you get a solid light, you can connect it to your phone...and if you just bought the headset, you should have an instruction manual. it will tell you in there how to make it work
Nov 04, 2007 | Motorola Mobility H500 Wireless Headset
Blue tooth
Most phones that support bluetooth have a "headset" or "hands-free" profile that the device must be in for the bluetooth headset to work. Can you confirm that your device is in this profile?
Jun 06, 2007 | Motorola Mobility PC850 Wireless Bluetooth...
Phone wont detect bluetooth H700
Mine could be discovered when powered off/ on my cellphone and retried... Sounds like solution to M$ programs, eh? :)
Apr 18, 2007 | Motorola Mobility H700 Wireless Headset
Just Wireless Bluetooth Headset Wireless Headset Logo
600 people viewed this question
Top Just Wireless Radio Communications Experts
Rocketmanusa
Level 1 Expert
Anthony Ward
Anthony Ward
robert
Are you a Just Wireless Radio Communication Expert? Answer questions, earn points and help others
