Question about Nokia 3230
White lighte display problem - Nokia 3230
Posted by kumarnaveen_ on
My washing machine just turns white light on display but nothing to display and white background light also comes when i turn it 2 times on n off
Good Morning Friend,
I understand you are having trouble with the display on your Electrolux washer, model# EWX14450W. In researching your model number, I have determined that it was manufactured in the UK. I suggest contacting the manufacturer for further assistance. They should be able to point you in the right direction for having your display repaired. Hope this is helpful.
-Best Regards-
WP
Jul 06, 2014 | Electrolux Washing Machines
Nokia 114 display not working
nokia white display model-144
Apr 11, 2013 | Cell Phones
Samsung mobile gt-c3200 no display only white light
samsung gt-c3200 on disply, LED of problem
Apr 12, 2012 | Samsung Cell Phones
HI, I HAVE A SYLVANIA MODEL SA 170 , I CAN´T SEE THE NUMBERS WHEN I´M IN FROM THE SCREEN, IT´S APPEARS VERY DARKS
If I understand correctly, you have Sylvania 170 timer and the display doesn't light up.
If you have different problem, add a comment.
A) If this is existing installation and timer display worked correctly before, then it sounds like timer malfunctioned or power to timer is interrupted. Check breaker, and then pull out timer and test for power.
B) If this is new installation, then 2 possible things:
1) Timer defective: exchange for new one.
2) Timer not wired correctly.
Review wiring:
Timer replaces single pole switch.
Single pole switch has two wires
Timer has 3 wires: Blue Black White
Timer has additional wire to run internal clock and to light up display.
If timer not wired correctly, then display will not light up.
Here is correct wiring:
a) Two wires from switch.
b) Connect timer-blue wire to one of the switch wires. Choose either one for now. You will have to choose other wire if display doesn't light up.
c) Connect timer-black wire to other switch wire.
d) Timer-white wire does NOT connect to either switch wire. Look in back of electric box. There are white wires twisted together and covered with wire nut. These are neutral wires. Connect timer-white wire to neutral wires. This will power the clock and display.
e) If your box does not have the white wires described in d), then connect timer-white wire to bare ground wire.
f) Turn power ON. Does display light up?
g) If display lights up, switch is wired correctly.
h) If display does not light up, then reverse timer-blue wire and timer-black wire shown in step b) and c).
Dec 02, 2010 | Zip Heaters Sylvania SA170 15 Amp Zip-Set...
Light/white screen display
Most likely a bad LCD display. Please see this link:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Jul 24, 2010 | Garmin Nuvi 350 Car GPS Receiver
Nokia n81 display white solution
change it silide patta
Jun 23, 2010 | Nokia N81
Sony erricson f305 mic problem and G502 blank display problem and k810i blank display problem show me the details with circuit pcb diagram and solve my problem.
first mobile was ok. problem was display white light. i changed the strip .now no white light and front keypad light .i changed the display,main strip also but of no use .pls suggest something
May 15, 2010 | Sony Ericsson F305 White +512MB Unlocked...
Nokia 3230 Logo
228 people viewed this question
Top Nokia Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
sandyp4ever
sandyp4ever
Level 1 Expert
Marvin
Marvin
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
