Question about HP LaserJet 4000 Printer
Change the language on hp laserjet 4000 to english
Posted by patoco_gh on
Computer Links
  • HP Master
  • 2,386 Answers
For the LJ4000 to change the control panel language:
Turn off the printer.
On the front panel, hold down the SELECT key.
Turn the printer on, while continuing to hold the SELECT key.
When the Select Language message is displayed release the SELECT key.
Initializing will display on the control panel. After 5-7 seconds Language=English will display.
Press the VALUE key until the desired language is displayed.
Press the SELECT key and an asterisk will appear. The asterisk indicates that the printer has saved the new setting.
Press the GO key to display Ready in the language that was selected.
NOTE: If Select Language does not appear in the display, hold down the SELECT button until you hear the motors rotate, then release. Following printer initialization, the Language= menu will appear in the display.
hope it helps, if so do rate the solution
Posted on Nov 30, 2010
How to change the language settings from chinese to english in hp printer m1218nfs
Press Menu button..one time
Press " >" arrow button seven times,
Press enter,
Again press enter.
Go to English language with help of arrow buttons, to save the language press enter..
Aug 19, 2014 | HP LaserJet Office Equipment & Supplies
Changing the language
Press and hold SELECT while turning on the printer. Hold SELECT until "Select Language" appears.
Release SELECT. INITIALIZING appears. Wait for LANGUAGE=ENGLISH to appear.
Press -VALUE+ repeatedly until the desired language appears.
Press SELECT to save your choice. An asterisk (*) will appear beside the selected language.
Press GO to exit the menu.
Oct 06, 2011 | HP LaserJet 4000 Printer
Hp laserjet 2840 - need to reset language to english from a foreign language I do not understand
Under device settings Go to system settings, Then go to system setup. You can change the language from there.
Nov 06, 2009 | HP LaserJet 2840 Printer
Language selected not available massage on printer HP4000n
the language option is available in the printer menu.
Dec 01, 2008 | HP LaserJet 4000 Printer
3050 All-In-One Printer
how do I change the language? everything is in German.
Nov 11, 2008 | HP LaserJet 3050 All-In-One Printer
SEQUENTIAL LOADING OF PAPER
I sent you the userguide downloaded from HP website.
Thanks.
Oct 21, 2008 | HP LaserJet 4000 Printer
CHANGING PRINTER CONTROL PANEL LANGUAGE
See solution below:
1. Turn off the printer.
2. Press 'select' and turn on the printer. (select button should be pressed while turning it on)
3. press '-value+' to choose your language
4. press 'select' to save
5. press 'go' to return to ready mode.
Thanks
Sep 10, 2008 | HP LaserJet 4000 Printer
Change language on printer menu
i wan to change language in my printer hp laserjet 3030.
i can not under stand china language i want to change in english
please give me instuction
Aug 27, 2008 | HP LaserJet 3030 All-In-One Printer
HP Laserjet 3030 printer/scanner/fax Language has
press Enter bottom
press left arrow key twice
press enter key
select the language you need then press inter
Mar 25, 2008 | HP LaserJet 3050 All-In-One Printer
How can i change HP laser jet 3030 printer's language?
Mar 17, 2008 | HP LaserJet 3030 All-In-One Printer
HP LaserJet 4000 Printer Logo
1,474 people viewed this question
Ekse
efs_perpends
efs_perpends
