Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
Can we relight the pilot manually or do we need an electronic lighter? Ours appears to have gone out. Also please verify that what we're looking at IS the pilot light! Thank you!
Posted by kellie_kilgo on
Paul Carew
  • Coleman Master
  • 3,527 Answers
If it is a permant pilot then you can light it manually , if is a hot surface ignitor then you will have to replace it , some electronic ignition has to be replaced , as it self lights .
Hope this helps you
Posted on Nov 30, 2010
How to relight pilot on boiler
Every boiler will have manufacturer lighting instructions on the unit, so be sure to read it thoroughly and turn off the gas for 5 min to make sure there is no gas build-up around the boiler. Some have electronic ignition and some require a manual lighting of the pilot. If the control knob has only ON-OFF, it has electronic ignition. Simply turn off the power (at the electric switch on the boiler or at the breaker box) and then turn it back on and it will relight itself when heat is needed) If it has ON-OFF-PILOT, you will have to light it manually. You will have to turn the gas valve knob so the arrow is pointing at the word "pilot" and depress the knob, while lighting the pilot with a lighter or match. Continue to hold the knob down after the pilot is lit for about 30-45 seconds to allow the thermocouple to heat up. If you release the pilot knob and the pilot stays lit, you can turn the knob to the "ON" position and the burner will light. Please be careful. if you are not sure what you are doing, call a professional.
Mar 01, 2015 | Heating & Cooling
Kitchenaid stove top (17 years old) pilot light is out. How can I relight it?
To relight it you need to pick up the top from the front and then relight the pilot that is in the center between the burners with a match or a lighter...
heatman101
Apr 23, 2011 | KitchenAid Microwave Ovens
Have a Model #21V40-7 Natural Gas Rheem water heater and the pilot has apparently gone out. Can you tell me how to restart the pilot and what position the controls should be in for this model and...
The main control knob will have a "Pilot" position. Set it there, then light the pilot. You may have to press and hold the control knob to do that. There may be a striker button that will relight the pilot while you're holding the control knob or you may need to use a match or a candle lighter.
Once the pilot is on for 30 seconds or so, it will remain lit when you release pressure on the control knob.
Dec 27, 2017 | Kitchen Ranges
Lighting the pilot light on a Worcester 24CDi combi boiler.
Most of these boilers don"t have a permenant pilot light they have electronic ignition that lights the burner when you are calling for heat or hot water, is there enough water pressure in the boiler ( there is a small gauge on the bottom r/h side of the boiler the needle should be sitting at between 1 - 2 if not enough pressure the boiler won"t light )
Apr 23, 2010 | Heating & Cooling
Pilot light gone out. How do I relight? Which
In general, large button from gas valve push in & hold 20-30 secs at same time push electronic lighter/ignition button to light pilot. Remember to hold in only gas button. the pilot light heats up a thermo couple [u can see this in the flame] and when hot enough allows the main gas through and the pilot to remain on.
If not then either thermo couple not heated for long enough or
it may need replacing
Oct 22, 2009 | Bosch Water Heaters
Heater won't relight or turn back on after the thermostat turns
Verify that your pilot is staying on if you have a pilot.
Some may have electronic ignition.
Oct 01, 2009 | Williams 1403622 Gas Compact Heater
My pilot light also just went out on my water wizard 13P when you relight ensure all buttons are equal in height or none depressed then hold far left button down whilst striking ignition button till pilot light ignites keep left hand button depressed for a further 3 seconds after pilot light has ignited I hope you have hot water then
May 22, 2009 | Audiovox Bosch 718 World Cellular Phone
Need to turn on pilot light of Williams 3003622 serial # 400518D
Find the gas valve and turn it to pilot. (Or light) Use a long reach lighter. Light the lighter and press the knob in. Light the pilot and continue to hold the knob in for about 15 seconds. When you release it, the pilot should stay lit. If it doesn't, you need a new thermocouple. That's the small tube that the flame touches when the pilot's lit. They're inexpensive and usually not too hard to replace.
Jan 30, 2009 | Williams 3003622 Ceramic Wall Mounted...
Potterton FF80 boiler, pilot light has gone out how do we relight
if you can see where the pilot is you can turn the gas in the on position and use a long candle lighter and manualy light it but be careful doinng so
Nov 12, 2008 | Stiebel Eltron DHC Instant Tankless...
Heating & Cooling Logo
148 people viewed this question
Top Coleman Heating & Cooling Experts
Paul Carew
Marvin
Marvin
jdthefixer
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
