Inverter KEB COMBIVERT F5 Logo
Raj Dhiman Posted on Nov 30, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Inverters stops without any error but can buss communicates inverter error!!!
mntech1
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
New Friend:
  • Inverter Expert 120 Answers
  • Posted on Dec 06, 2013
mntech1
Inverter Expert
Level 2:
Mentor:
New Friend:
Answers
120
Questions
0
Helped
78022
Points
185
If the inverter is not displaying an error but the CANbus system is showing an error, the problem is with the communications.
Could be a faulty CANbus system, operator in the inverter or possible EMI issue.
KIPOR 3000TI INVERTER. Kipor 66284 DC Receptacle. Can I run it without one safely?it's been removed
It's generally not recommended to run a KIPOR 3000TI Inverter without the Kipor 66284 DC receptacle. The DC receptacle is an important safety feature that helps to protect the inverter and any connected equipment from damage. If it has been removed, it's possible that the inverter may not function properly or may be at risk of damage.
If the DC receptacle has been removed and you are experiencing issues with the inverter, it's best to contact a professional repair service or the manufacturer for further assistance. They will be able to diagnose the problem and recommend the appropriate repairs. It's also a good idea to stop using the inverter until the issue has been resolved, as continuing to use it without the DC receptacle may cause further damage or pose a safety risk.
Voltas inverter split ac showing e4 error code and got shut down after 5 minutes what is the solutions
My voltas inverter ac e4 error which is communication error.It works fine in sunny day but stops in night or rainy day and shows e4 error.
1helpful
How to fix a E9F error code of EWF1282 FRONT LOADER ELECTROLUX WASING MACHINE
E9F - Communication error between main PCB and Inverter board.
Could be:
  • Faulty wiring between main PCB and Inverter;
  • Inverter PCB faulty;
  • Main PCB faulty
Dado
I have a KEB combivert F5. The parameter ru 00 shows nop even if i give switching to terminal 16 for control release.Please help.
This may be due to the inverter waiting for an ST signal via buss communications.
What is the part # of the unit in question?
The inverter is recognizing that terminal 16 is going active but still waiting for another command to enable the inverter.
We have electricity to operate the microwave and plugs but the lights are operating off of the batteries. Is this a converter problem? If so is it a fuse on the converter? Doesn't appear the aux...
The microwave and outlets are on a 115-120vAC source running through the breakers box. The lights are 12vDC running through the converter then to the fuse panel. Locate the inverter in the compartments up front, possibly behind a panel that can slide or screws to hold the panel. Depending on the Mfr if the inverter, you should see a blade style buss fuse on the side, typically near the 12vDC output. Use a multimeter to check for the 120vAC input and 12vDC output. AC power-yes and DC power-no, check the fuse, replace if necessary. If the fuse is good, the inverter has blown and needs to be replaced. If you have AC & DC power on the inverter, go to the batteries and check for voltage without the inverter supplying power. Pull the fuse off the inverter or switch the battery disconnect switch. If the batteries have little to no voltage, cells may be dead. Take the batteries to a local auto parts store to get checked to see if the battery needs a charge or replacement.
Mar 02, 2018 • RVs
What Error COM KEB mean ????i have F5 version
The KEB inverter does not have a "COM" error.
Where is this error being displayed?
Check your inverter baud rate, inverter address, communications cables and device that is being used to communicate.
Problem E9F
communication error between PCB and Inverter,
Check wiring,PCB and inverter.
12helpful
2answers
Error e6 displaying on single split model one inverter 12k
I have a DeLonghi one inverter and when I want to turn On the heater then the code error display E6 and the error code is Communication malfunction. So can you tell me how can I fix it
Top Inverter Electronics - Others Experts
Ngoro
john h
Are you an Inverter Electronics - Other Expert? Answer questions, earn points and help others
