SOURCE: Texas Instrument BA2 NPV problem
After you enter the value, you have to press enter so the value is saved for the calculation.
SOURCE: how to calculate log value in calculator with different base value
In any scientific calculator log2(n) can be calculated with either ln or log function as
follows
Log2(n)= ln(n) / ln(2)
Or
Log2(n)=log(n) / log(2)
both will give nearly the same answers
SOURCE: I need to calculate NPV
Did you take into account that you have beginning of the year payements? Your calculator probably treats it as an end-of-the-year payment? Did you try treating the first payement as an initial cash flow (should be available as an option in your calculator input) and the treat the three remaining years as end of the year payements at your 9% rate. It should do it.
SOURCE: how calculate perccentages on a calculator
There are two ways to do this. First you can enter the number that you need to calculate the percentage of, times the percentage amount and the the % button.
e.g. 100 x 50 % =
This will show you the amount that 50% is as soon as you push the % button and then will caculate the total when you push the =.
You can also multiply the number by the percent amount with the decimal moved two places to the left.
e.g. 100 x .50 =
SOURCE: Calculating PV where n=5; i=6%; $18,400=pmt; 0=FV.
Check to make sure you have the proper value set for payments-per-year.
